Door Glass in 1927 Coupe
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
How difficult should it be to roll up the door glass? I have installed new safety glass in the drivers side door, and it is very, very hard to roll up. The glass is very tight in the channel.
I am in the process of installing the glass in the passenger side door. I have placed the glass into the channels but have not installed the raising mechanism. I can barely move the glass up and down by hand. It is that tight in the channels, so the mechanism would never be able to raise the glass.
The original glass was used by the glass store to cut the new glass. I am considering having the store make two new pieces that would be cut 1/8 inch narrower.
Distagon2
Re: Door Glass in 1927 Coupe
When I restored my 26 coupe, this had to be one of the most time consuming, labor intensive tasks. The window should really be able to roll up and down with relative ease with the hand crank. I suspect your reproduction channels might be a tad too "fat" causing binding. Is it possible to remove material from the backs of the channels, then try the fit? This is what I had to do....several times. One word of caution is to go slow when removing material from the backs of the channels. If you remove to much, then the glass becomes sloppy in the channel and can wedge which is as much of a headache as you have now. Of course if you do remove too much, you can shim it back. Hope this makes a little sense.
I would think that you could have the shop cut some new glass narrower, as you say. You may still need to custom fit those channels to get it just right.
jsaylor
- Last Name: Saylor
I had similar troubles using the vendor channels on my 27 Tudor. I ended up returning the kit and using channel sourced from Stanpro. They have been merged with another company now. I had to transfer the clips from my old channel to the new.
BLB27
- First Name: Bruce
- Last Name: Brakke
Thanks Gregory and John that's useful information.
I would also appreciate input from others.
BLB27
- First Name: Bruce
- Last Name: Brakke
If I decide to replace the new glass and have the replacement cut narrower, how much narrower should I make it? Any opinions would be appreciated.
Distagon2
Rather than cut new glass, I believe you can take your glass back to the shop and they can sand down the edges. How much? Hard for us to say, really, without "being there." I would take a little off (assuming the shop will cooperate with you) and tell them what you are trying to accomplish. I would take (just guessing here) about 1/32" off and try the fit. Rinse and repeat as necessary. All this assumes the glass shop will work with you.
BLB27
- First Name: Bruce
- Last Name: Brakke
It is tempered glass. I will check with store, but I believe the edges can't be sanded.
Distagon2
Yeah, I thought about that just a few minutes ago. Works with laminate, but surely not with tempered glass! You could go the route of cutting new glass and if you think 1/8" less in width might do it, then go with that. If that turns out to be too much you can shim behind the felt channels to get it just right. As I said earlier, I spent a lot of time getting the glass in the door windows "just right" so they would roll up and down like they did when new. It is worth the effort, hang in there!
