1915 machined hub
Topic author - Posts: 42
- First Name: Michael
- Last Name: Royster
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
1915 machined hub
I am looking to buy a machined hub for my 15 T so that I use the speedometer that came on the car, and the car has unknown wire wheels. Attached are the pictures of the hub I need. Thanks much!
Mike Royster
mr@carolina.rr.com
704-418-1177
Mike Royster
mr@carolina.rr.com
704-418-1177
Re: 1915 machined hub
Are you running ball bearings or Timkens ?
Unsure as I just got the car a week ago. I can pull the wheel and see. Tell me the issue please.
Thanks,
Mike
Thanks,
Mike
No issues - I'm thinking Ford produced a machined hub that took Timken bearing also - I have a couple - I'll check.
Thanks, I will too!
You are correct Steve, Timken bearings! Would you be willing to part with one so I can use my speedometer?
Thank you,
Mike
Thank you,
Mike
- Last Name: Meixner
Most are probably roller bearing. All have short hub cap shoulder.All for sale $75 each
