Upholstery with patina
Post by Allan » Thu Mar 30, 2023 5:53 am
In Bushmike's post on his re-awakening his TT, he mentioned new upholstery for it. I suggested using pre-used material.
Here is the trim in Henrietta. Her upholstery was all bu eaten out by mouse plagues during her 63 year slumber. This upholstery was in a car I restored for a customer. I kept it for patterns so others could copy the methods of Duncan and Fraser in building their cars in South Australia. All I had to do is trim off one of the pleats from the backrest and add a small piece to one side of the seat cushion.
The top material is from that same car. I suspect it was an early replacement for the original top. Again, it took very little work to make it fit..
I can honestly state it is original upholstery, just not original to Henrietta. Amazingly, she still has the original dark green covered door cards, and the kick panels on the sides of the cowl. This was the first D and F car to have kick panels.
If any of you have such material stashed away, it can be put to good use on an unrestored car.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Re: Upholstery with patina
Post by BUSHMIKE » Thu Mar 30, 2023 6:04 am
Allan,
That is super cool! I like it.
Model T Matt
First Name: Matt
Last Name: Madison
* REQUIRED* Type and Year of Model Ts owned: 1923
Post by Model T Matt » Thu Mar 30, 2023 9:59 am
Had a friend that got a few old leather couches to redo his car
