Datsun B-210 series Oil pump
Ericgj85
First Name: Eric
Last Name: Johnson
* REQUIRED* Type and Year of Model Ts owned: 1926 speedster
Post by Ericgj85 » Mon Apr 10, 2023 5:23 pm
Looking for the adaptor if anyone has one laying around.
Thanks,
Eric
First Name: Henry
Last Name: Lee
Re: Datsun B-210 series Oil pump
Post by Henry K. Lee » Mon Apr 10, 2023 5:43 pm
My local scrap dealer had about 25 about 1 year ago I delivered. I believe my cousin in China has converted them into tv mounting brackets at Walmart.
Ericgj85
First Name: Eric
Last Name: Johnson
Post by Ericgj85 » Mon Apr 10, 2023 5:52 pm
"Henry K. Lee"
I knew you would comment ! I wish you would have kept some all of the info I could find would lead me back to that post about scrapping them!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Apr 10, 2023 6:41 pm
I see the pump is available on Rockauto. “Inventing” the bracket isn’t that difficult.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Mon Apr 10, 2023 8:09 pm
He DID say he was looking for an adapter; not the pump. He evidently has, or has access to, a pump. Yes, the adapter is not complex, but if you have one, it is a lot easier to bolt one on, than have to make or machine one. Not everyone has a machine shop or the skills.
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Tue Apr 11, 2023 12:51 pm
Dan McEachern probably has some laying around.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Apr 11, 2023 7:35 pm
Actually, i do not- never made any- tried to buy some pumps for another project, but that did not go so well....... Kirk Wright made some up for sale many years ago but ...........
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 11, 2023 8:18 pm
I have one of Kirk Wright’s. I did a bit of “tweaking” and plan to run it finally in the next couple of weeks.
You can see it here!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Apr 11, 2023 8:23 pm
I just took mine off my speedster engine to install my alternator/oil pump drive… but my dad quickly claimed it for himself.
I do suggest seeking out an iron Melling pump rather than the lower precision aluminum alternatives. The iron pump I removed had very little noticeable wear after 10+ years. I am happy to make up a sketch of the adapter I removed if this helps
Ericgj85
First Name: Eric
Last Name: Johnson
Post by Ericgj85 » Tue Apr 11, 2023 8:38 pm
Okay Kevin if you could email a picture / sketch that would be a good start ! Email is ericgj85@aol.com
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Tue Apr 11, 2023 9:47 pm
Kevin, I (and I am sure others as well) would appreciate it if you would post that information here also. Thank you for sharing your ongoing OHV build-up on your own thread— enjoy seeing your amazing skills!
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Wed Apr 12, 2023 9:16 am
There was a guy from the Pacific NW selling the adapters at the Spokane swap meet last July.
He was machining them himself.
I bought one from him.
Our Washington or Oregon friends may know who he is?
Harry
Mikes 1912
First Name: Lester
Last Name: Husted
* REQUIRED* Type and Year of Model Ts owned: 20
Post by Mikes 1912 » Wed Apr 12, 2023 10:47 am
The cost of the pump is out of site. The last ones I bought was $260. If you can beat that price let us know where and how much.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Apr 12, 2023 11:10 am
I just checked Rockauto. The aluminum one is $65.00 and the Melling iron one is $189.00. And that’s Canadian $
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Apr 12, 2023 4:51 pm
Here a quick look at what I made all those years ago…
Rough material dimension is 3.5” x 3.5” x 2.0”. Could probably take an inch off the length as the “snout” isn’t necessary. When I made this, I wanted to add a ball bearing to take the radial gear load but never did. After all these years the pump is in good shape, so bearing not needed. A simple register into the generator bracket will do
Dan McEachern
First Name: DAN
Post by Dan McEachern » Wed Apr 12, 2023 7:34 pm
If someone is going to do this, I'm machining generator gear blanks as I type this and could make some with a .490" bore to fit the Datsun pump shaft.
Just stirring the pot a bit................
RichJ
First Name: Rich
Last Name: Jesteadt
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
Post by RichJ » Wed Apr 12, 2023 10:15 pm
I have a block thatis someones unfinished project from many years ago It has a datsun pump bolted on it
I'm not able to get to it for about a week,to get pictures. It could be in Luray if intrested! Rich 561 262 0393
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Wed Apr 12, 2023 10:19 pm
Dan, I'll take one. It will keep me from having to put a brass bushing in a T generator gear.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sat Apr 15, 2023 2:07 pm
Be aware if you are purchasing a Melling pump- the Melling #M90 Nissan B-210 pump does not include the input shaft or the gerotor. The correct part number to purchase is the # M90A and is a complete pump. Just FYI.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Apr 15, 2023 10:08 pm
Looking at the pictures of the two versions of the B210 pump offered on Rockauto they certainly appear to be complete.
