Fuel Injected t
Topic author - Posts: 117
- First Name: Philip
- Last Name: Berg
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1916 Coupelet
Fuel Injected t
In a nutshell I'm using a Honda CB250R integrated TBI, VW smart coil and a Speeduino NO2C DIY kit. Merging modern electronics to a hand cranked primitive engine was quite a challenge but I figured out a work around for most problems. Still in the tuning stage but it's slowly running better.
Please no haters.
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, T speedster
Re: Fuel Injected t
Interesting project. Hope to see more updates on how it runs and more pictures of the car.
- Last Name: S
Re: Fuel Injected t
Is that a thermocouple for coolant temp on the hose flange at the head?
________________
**FATE**
**FATE**
- Last Name: Berg
Re: Fuel Injected t
GM temp sensor
- First Name: Leo
- Last Name: van Stirum
Re: Fuel Injected t
Interesting setup ! Some sort of time machine
Leo van Stirum, Netherlands
- First Name: Henry
- Last Name: Lee
Re: Fuel Injected t
Looks like someone is having fun with experiments..., I like it when the normal is not normal!
- Last Name: Burgett
Re: Fuel Injected t
I saw fuel injected model T speedsters at the Newport Hillclimbs several years ago. they were Hilborn type on side of engine.
Have fun with your project.
John
John
- First Name: Andrew
- Last Name: Clary
Re: Fuel Injected t
How do you prime for hand cranking?
Andy
Andy
- First Name: Susanne
- Last Name: Rohner
Re: Fuel Injected t
Definitely no hate here - I think it's neat when you can take a 100 year old engine and use it as a test bed for a project.
Lots of questions - A few to prime the (water) pump
(1) How are you timing the coil system? I get the Honda syatem as a "smart coil" but you need some way to time the thing.
(1a) Do you still have manual control over the ignition timing, and if not, how do you keep from fracturing your arm?
(2) Does running this result in a cleaner/smoother/more bulletproof running T engine?
(3) Are there any performance plusses and/or minuses?
(4) What's next? Turbocharging? A blower? (I'm guessing at that point pressure oil would also be in the mix)
Re: Fuel Injected t
A propane conversion, or a propane/gasoline system, would give some of the advantages of fuel injection. Where to put the tank would be an issue, except in a pickup or TT. High compression would offset lower BTU. Hard seats and stainless steel valves might be needed.
- Last Name: Berg
Re: Fuel Injected t
Here's some answers:Susanne wrote: ↑Mon Jun 05, 2023 9:18 amDefinitely no hate here - I think it's neat when you can take a 100 year old engine and use it as a test bed for a project.
Lots of questions - A few to prime the (water) pump:
(1/1A) Anderson timer is used, advance/retard is manual just as Henry designed it. I designed and built a couple of circuit boards to fire the VW smart coil from the Anderson timer.
(2) I haven't shot a bullet at the engine yet so I can't say, still tuning.
(3) Still tuning, I can say that my engine does not like to run stoichiometric (14.7:1) like modern automobiles. My guess it has something to do with cam design and overall engine design.
(4) No further mods are in the future except getting the ECU to control timing. I have to create a circuit for that and at this point I have other projects that need attention
Re: Fuel Injected t
A mild cam and high compression would probably help burn leaner mixtures. Valve stems seals and precision-fit pistons & rings would also help as would a high operating temperature and intake air heat.
Side valve engines with huge combustion chamber volume don't like a lean mixture.
