counterbalanced crankshaft what make??
Topic author - Posts: 38
- First Name: K
- Last Name: Mowle
- * REQUIRED* Type and Year of Model Ts owned: Ames Model 814 Speedster, Peerless barn find Speedster
Hi,
Recently, dug this out of the shed.
Included are the markings on a counterbalance crankshaft. Does anyone have an idea who made this?
thanks
Kevin
thanks
Kevin
Re: counterbalanced crankshaft what make??
Shermike. They made 3 versions. Not enough seen to determine which one.
- First Name: Erik
- Last Name: Barrett
Sure break crank. Hang it on the wall.
Amen.........
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
Been there and done that Tom
- First Name: Warren
- Last Name: Webb
Got 2 around here been running them for over 30 years no problems.
- First Name: Gene
- Last Name: Carrothers
I'm sure there is another SureBreak crank that has been running for nearly a hundred years BUT unfortunately one of our club members recently rebuilt his engine not knowing the reputation with a SureBreak crankshaft that had been checked out.
It broke in a very short time of driving! Was a sad learning experience that he didn't know before so he could have made an informed choice.
1912 Torpedo Roadster
Looks a might short John !!!
- First Name: Gene
Now that one looks pretty nice. it's got some scarring near the front seal and pulley but looks a little short on the back end??
I have a couple of cranks here in the shop with the same problem!
- Last Name: Tannehill
Yep that one left a mark. Approximately How much JB WELD will I need to repair it properly? Jim the 4 attributes should be:
More power
More Speed
More POP
More engine pulls
More power
More Speed
More POP
More engine pulls
- First Name: Terry
- Last Name: Woods
John, How can a person tell them apart? I have two, one in a running engine and a spare. I'd like to know if the spare is one of the better ones.speedytinc wrote: ↑Mon Sep 25, 2023 12:39 pmShermike. They made 3 versions. Not enough seen to determine which one.
- First Name: Joe
- Last Name: Bell
years back I checked the metallurgy of them and they where high Cromium in them like the Dodge Bros. cranks.
The difference is the size of the counter weights. I believe the "short" one shown is the best #3. #2 are a smaller dog bone shape. #1 has very little counter weight. This is from research basically looking @ aftermarket adds long ago.ModelTWoods wrote: ↑Wed Sep 27, 2023 11:35 pmJohn, How can a person tell them apart? I have two, one in a running engine and a spare. I'd like to know if the spare is one of the better ones.speedytinc wrote: ↑Mon Sep 25, 2023 12:39 pmShermike. They made 3 versions. Not enough seen to determine which one.
- First Name: Randy
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1910 Speedster, 1915 Speedster, 1924 Roadster, 1926 TT, 1923 boattail (project)
Any ideas on the make of these two? At this time they are wall hangers, so if anyone can shed light on whether or not they are worth the $$ and time to finish them I would appreciate the info.
- First Name: Terry
- Last Name: Woods
John, Where are the pictures (#1, #2, #3) that you mentioned?speedytinc wrote: ↑Thu Sep 28, 2023 8:25 amThe difference is the size of the counter weights. I believe the "short" one shown is the best #3. #2 are a smaller dog bone shape. #1 has very little counter weight. This is from research basically looking @ aftermarket adds long ago.ModelTWoods wrote: ↑Wed Sep 27, 2023 11:35 pmJohn, How can a person tell them apart? I have two, one in a running engine and a spare. I'd like to know if the spare is one of the better ones.speedytinc wrote: ↑Mon Sep 25, 2023 12:39 pmShermike. They made 3 versions. Not enough seen to determine which one.
I think From various accessory books. Its been a while. Past vintage fords likely. Also in various accessory compilation books.
- Last Name: Meixner
My understanding from old timers, is that there are 2 different counterbalanced cranks. 1 that is prone to break, and 1 that (can't) be broke.
I have no idea how you tell the difference. Wished I knew.
I have 1 that I got used that has 5,000 miles at 60 MPH and still going.
