WANTED 1923 ENGINE BLOCK
Stephen1915
First Name: Stephen
Last Name: Noll
* REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet & 1911 Torpedo
Post by Stephen1915 » Tue Dec 05, 2023 4:35 pm
Want to buy a 1923 Engine Block or complete engine. Must be 1923.
314-287-1901
Located in St.Louis Missouri
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: WANTED 1923 Ford Title.
Post by Chris Haynes » Tue Dec 05, 2023 7:58 pm
When I need a title I simply go to the DMV and fill out an Application For Title and get one the right way.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Wed Dec 06, 2023 7:40 am
Some States is a whole lot harder to get one than others, Ohio you stole it till proved other ways and that is expensive!
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Wed Dec 06, 2023 9:30 am
Still looking!
Stephen1915
First Name: Stephen
Last Name: Noll
Re: WANTED 1923 ENGINE BLOCK
Post by Stephen1915 » Wed Dec 06, 2023 2:37 pm
To the top
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Dec 06, 2023 2:44 pm
Your ad says you want a block, but the headline on the first three responses say you want a title. Which is it?
I might be able to help if you are indeed looking for a 1923 block.
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Wed Dec 06, 2023 3:31 pm
Adam, I have found out all I need is a block to obtain a title in my state. The car needs a complete engine anyway as it does not have one. Looking for a block or complete engine. Car is a low radiator steel firewall car, April-May-June build I would suspect.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Dec 06, 2023 5:19 pm
Stephen, I sent you an email.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Wed Dec 06, 2023 5:25 pm
I Have serial numbers that came off of blocks before they went to the foundry, you can stamp them on your block, free!
Michael F
First Name: Michael
Last Name: Feller
* REQUIRED* Type and Year of Model Ts owned: 1918 touring 1927 touring
Post by Michael F » Wed Dec 06, 2023 11:01 pm
I am in west plains Mo south central I will check to see If I have a 23 block I have several blocks and engine and transmission parts ETC
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Thu Dec 07, 2023 1:44 pm
Thank you guys!
Michael F
First Name: Michael
Last Name: Feller
Post by Michael F » Thu Dec 07, 2023 11:16 pm
I have checked and I have 17, 19 22, 24, 25, 26 Blocks but no 23 Sorry I cant help you
pre15dale
First Name: Dale
Last Name: Kemmerer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Post by pre15dale » Fri Dec 08, 2023 4:22 pm
Steven, I have a block, engine number 7555361 which puts it April 28, 1923 I believe. It's a bare block with main bearing caps and bolts. I also have most all parts to make a complete engine, will sell just the block or a package. reasonable
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Fri Dec 08, 2023 4:44 pm
Dale, Thanks for the call.
