Chickasha swapmeet items
Gene_French
Topic author - Posts: 1048
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Chickasha Swapmeet items : will have a Brassworks low radiator ( possibly used to test run an engine and then returned to original shipping box ) , 4 nice 19" Model A wire wheels , 2 T wire wheels ,1928-29 A front fender ( restorable ) my Babbitt bearing molds and linebore units ... i am located in the South building ,spaces SL4-SL6 ...see you all there Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
- First Name: Gene
- Last Name: French
Re: Chickasha swapmeet items
i have added 2 bench vises , a single point Mallory ignition for model A , a Wico magneto for stationary motor or tractor ... see you all there Gene French (SL4-SL6 )
Gene_French
- First Name: Gene
- Last Name: French
will be out ahead of the snow tomorrow morning ( i hope ) ... see you all there ...Gene French
- First Name: Keith
- Last Name: Townsend
Drive safety. See you there!
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
Gene, Is your Brassworks radiator a round tube or flat tube radiator? Russ Furstnow
Ed Donnelly
- First Name: Ed
- Last Name: Donnelly
- * REQUIRED* Type and Year of Model Ts owned: 25tt, 26roadster, 26coupe, 24touring, 26roadster pu
Gene are you down sizing. Ed Donnelly here hope to see you there and I'll look at those finders. Booth right down from you.
Gene_French
- First Name: Gene
- Last Name: French
Ed:
not downsizing as such ... i plan on focusing on my 2 Dodge Brothers cars for my antique vehicles ... and i have been upgrading some of my basic shop hand tools ... for shop machinery i will retain my CNC mills , large conventional lathe ,surface grinder and Hansvedt EDM, but i am upgrading my small ( 13X40) conventional lathe and Index 747 turret mill and small CNC lathe ...i still enjoy my work and will continue to work at my Babbitt tools and repairs for several local plastic molding shops ... see you all at Chickasha ...Gene French
