TT Auxiliary Trans
desertexplorer
First Name: Wallace
Last Name: Bellows
MTFCA Number: 15547
TT Auxiliary Trans
Post by desertexplorer » Mon Jun 03, 2019 6:59 pm
I recently acquired a Lincoln over/under trans for my TT truck but it's missing the part (or parts) to mount the shift tower. Without it I have no way of mounting the shift tower to the torque tube. The photo shows the tower and shift linkage that I have.
Anyone know what parts I need to mount this?
Thanx everyone!
First Name: Adrian
Last Name: Whiteman
Re: TT Auxiliary Trans
Post by A Whiteman » Mon Jun 03, 2019 7:06 pm
Probably just a large "U" bolt.
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jun 03, 2019 7:07 pm
Just a big U-bolt, Wallace. It’s heavier than a muffler clamp bolt, but that may work for you. The right one would be pretty easy to make. There are a lot less shifters than transmissions that survived. Nice piece !
46woodduck
First Name: Thomas
Last Name: Petry
Post by 46woodduck » Mon Jun 03, 2019 7:26 pm
A rear axle U-bolt would probably work or you could probably just use a piece of threaded rod and bend your own.
desertexplorer
First Name: Wallace
Last Name: Bellows
MTFCA Number: 15547
Post by desertexplorer » Mon Jun 03, 2019 7:30 pm
I tried today clamping a u-clamp but you can't get it tight enough. When you go to shift there's a lot of torque from the shift knob and the tower slides left and right on the torque tube. Also, without the part the tower isn't high enough off the torque tube and the shift linkage binds. Not really sure what I'm missing...
RalphS in NE Oregon
First Name: Ralph
Last Name: Swinehart
MTFCA Number: 1386
MTFCI Number: 20289
Post by RalphS in NE Oregon » Mon Jun 03, 2019 7:54 pm
Wallace,
I have a Lincoln like that. You are missing a heavy casting that goes under the torque tube and bolts to the shifter with a bolt on each side. Mine also has a diagonal brace on each side that connects to the bolt that connects the two radius rods to the torque tube. This is what takes all the shifting load. Could your braces have been cut off? No time tonite but I will try to scrape the grease off tomorrow and get a picture of the shift tower in place.
Ralph
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jun 03, 2019 8:06 pm
Yes Wallace, what Ralph just posted is spot on ! I had to look at mine. You are missing a small casting that has ears to connect to the radius rods. If you need a sketch, just ask. Looks like a 5/16” u bolt, too. If you can’t make it, Hank in Tennessee sure could.
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jun 03, 2019 8:07 pm
Oh gosh, now original smith Is going to see another zerk fitting and go nuts again !
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Mon Jun 03, 2019 8:38 pm
Tim, we all seen it but we didnt say anything!😁
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Jun 03, 2019 8:40 pm
DAG NABBIT!
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Mon Jun 03, 2019 8:45 pm
I would just put floor boards over it and your good. :lol:
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Mon Jun 03, 2019 9:52 pm
Stick a hose on it and run it up towards the fuel tank !! :shock: :mrgreen:
desertexplorer
First Name: Wallace
Last Name: Bellows
MTFCA Number: 15547
Post by desertexplorer » Mon Jun 03, 2019 11:14 pm
Wow, I get back from my shop and get responses with photos even, that was quick!
I see the part that I'm missing, my guess is thst whoever removed the trans and shifter assy just removed the 2 top bolts and left the rest bolted to the driveshaft tube. My only option is obtaining a part to have a casting made or fab one up. A sketch of the part would be great, Thanks! (nice looking zerk too!)
