Unique swivel and fiber gear - ID requested
Retro54
Topic author - Posts: 590
- First Name: Andrew
- Last Name: Blaydon
I came across a photo of this swivel and fiber gear. The bracket looks like 1915 or so, but the strait drive swivel and large fiber gear are throwing me off. Is this model T hardware or for another automobile of similar vintage? Just curious to see what the experts say. Thank you in advance!
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
Re: Unique swivel and fiber gear - ID requested
The "direct drive" was used with speedometers that run 2008 rpms at 60 mph. These speedometers include Van Sicklin, Warner, Jones, Johns-Manville, Sears Cross, Standard Thermometer and early Stewart and Clark. I suspect this drive was used on a Van Sicklin, but have no proof without studying the unit closer. Phil Knighton reproduced these drives as a substitute for fragile 1:1 ratio swivels.
The "S" clamp is a brass reproduction and has no bolt going through it to tighten the clamp to the drive or "L" bracket. I hope this helps. Russ Furstnow
Retro54
Russ, thank you so much! I really appreciate your response. I should have added in my original post that I do have your MFTCA booklet "Identifying and Restoring the Speedometers used on the Model T Ford", but this particular set up had me thrown off, and so I asked. Over the last year or so, I've collected some heads and parts to replace the long lost speedometer on my January(ish) 1915 Cut-down touring. It's ALOT to learn, and I am appreciative of folks such as yourself whom have taken the time to collect information for the rest of us to build off of.Russ_Furstnow wrote: ↑Sun Apr 07, 2024 9:34 amThe "direct drive" was used with speedometers that run 2008 rpms at 60 mph. These speedometers include Van Sicklin, Warner, Jones, Johns-Manville, Sears Cross, Standard Thermometer and early Stewart and Clark. I suspect this drive was used on a Van Sicklin, but have no proof without studying the unit closer. Phil Knighton reproduced these drives as a substitute for fragile 1:1 ratio swivels.
-Andy
Retro54
Russ, one more question, if you do not mind. Would the swivel and fiber gear, if paired with a 58T 8P wheel gear, work to drive a 1916-ish Stewart Model 100 with a black face? Head would be similar to the head on page 26 of your book.Russ_Furstnow wrote: ↑Sun Apr 07, 2024 9:34 amThe "direct drive" was used with speedometers that run 2008 rpms at 60 mph. These speedometers include Van Sicklin, Warner, Jones, Johns-Manville, Sears Cross, Standard Thermometer and early Stewart and Clark. I suspect this drive was used on a Van Sicklin, but have no proof without studying the unit closer. Phil Knighton reproduced these drives as a substitute for fragile 1:1 ratio swivels.
Thank you in advance sir!
Andy
Russ_Furstnow
- First Name: Russ
Andy, The short answer is no. The Stewart Model 100 would use a 2.5:1 swivel. The drive you show is a direct drive 1:1 ratio. Also, a 58T gear is used on a 21" tire. I hope this helps, Russ Furstnow
Retro54
Russ, again, thank you very very much. I really appreciate your being willing to share your knowledge. I had been wanting to contact you in regards to some other assembly parts that I have. Would you mind that, and what would be the best way to reach you?Russ_Furstnow wrote: ↑Sun Apr 07, 2024 10:56 amAndy, The short answer is no. The Stewart Model 100 would use a 2.5:1 swivel. The drive you show is a direct drive 1:1 ratio. Also, a 58T gear is used on a 21" tire. I hope this helps, Russ Furstnow
Thank you,
Andy
Russ_Furstnow
- First Name: Russ
Andy, I sent you a PM. Russ Furstnow
