Sure Feed Oiling System For Sale Sold
elliott1936
Last Name: Elliott
Post by elliott1936 » Tue Sep 19, 2023 1:36 pm
This is an original Sure Feed Oiling System for the model T. It can used with the two different ways to drain the oil from the hogs head cover into the front of the pan. It has the original fitting that bolts to the pan to engine bolts and drains the oil through one of the bolts that would hold the pan to the engine. The way that I used this until I went to a full pressure system, was a fitting that was bolted into the side of the pan. A drilled hole with a fitting that drained the oil into the front of the pan. $100.00 plus the postage.
Tom five03-644-937four twoelliott@msn.com
elliott1936
Last Name: Elliott
Re: Sure Feed Oiling System For Sale
Post by elliott1936 » Mon Jun 24, 2024 1:30 pm
Repost this item for sale
elliott1936
Last Name: Elliott
Post by elliott1936 » Wed Aug 07, 2024 3:07 pm
If you can use this item I will take an offer. Tom
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Post by South Park Zephyr » Wed Aug 07, 2024 3:33 pm
Email sent
South Park Zephyr
Last Name: Francis
Post by South Park Zephyr » Thu Aug 08, 2024 3:31 pm
Check is in the mail
Thanks,
Scott
