I purchased this Rotary Valve cylinder head at a local auction several years ago. Since that time, I have been unable to locate any information on it. I thought I would share a few photos of it in the hopes that another forum member would recognize it or offer some suggestions on who I might contact for assistance in identifying it. It appears to me that it was originally designed to fit the "490" Chevrolet engine from the 1920's. Any help would be greatly appreciated.
Brian
Rotary Valve cylinder head identification?
Brian Cress
Topic author - Posts: 46
- First Name: BRIAN
- Last Name: CRESS
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, Roadster, Hack
Kevin Pharis
- Last Name: Pharis
Re: Rotary Valve cylinder head identification?
The basic profile does look a lot like the chebby 4… but looks like it may only use 8 of the head bolts. Could this be an air compressor conversion…? Are there spark plug holes?
Brian Cress
- First Name: BRIAN
- Last Name: CRESS
Hi Kevin,
Yes, there are spark plug holes visible on the right-hand side of the lower casting which is on the left side of the first photo.
Brian
Brian
Rod
- First Name: Rod
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
- Board Member Since: 2014
I recently watched a documentary on the Rotary Valve head. This link may have some useful info:
http://www.thegreymotor.com/2014/08/dun ... d.html?m=1
Brian Cress
- First Name: BRIAN
- Last Name: CRESS
Hi Rod,
That is a very interesting link. While I had found information on the Dunston and Coates efforts to create a rotary valve head, the "PatRoVa" and "Bishop" information is new to me.
Thank you for sharing!
Brian
Brian
