Cast iron warford install problem
Topic author - Posts: 81
- First Name: Jerry M
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring1927
I have tried searching for my particular problem with the installation of a 920-1 case iron case Warford in a 1914 Touring. Problem is - the center "U" shaped portion of the emergency brake shaft hits the front of the Warford preventing the Ford transmission from going into high gear. Has anyone experienced this problem and how did you fix it? TIA Jerry
- Last Name: Young
Re: Cast iron warford install problem
Sorry for the double entry - if this is not the proper section for this post ,I apologize!! Jerry
- Last Name: Young
All is good, the amazing Henry Lee came through for me - THANKS Henry!!!
