Fuel Tank drain bushing
suley
First Name: Suleman
Last Name: Ishaque
* REQUIRED* Type and Year of Model Ts owned: 1925 Model T Truck
Post by suley » Thu Dec 19, 2024 3:42 pm
Hello all,
The carb restoration took me to pay attention to the gas tank and after cleaning and sealing it, I have found that the sediment bulb wont fit. The PO has installed a brass bushing in the outlet and had screwed in a brass elbow leading to a copper line to a flex hose to carb. There was no sediment bulb.
I'd like to restore it to original and would like to remove this brass bushing so that the sediment bulb can fit. any ideas how to remove this bushing without causing damage to the tank?
Also, the tank is round and not oval. Will this cause issues once the sediment bulb is fitted on? not much clearance between the bottom of the tank and the drive shaft down there....
Any help would be most appreciated.
Last Name: Humble
Board Member Since: 2006
Re: Fuel Tank drain bushing
Post by Humblej » Thu Dec 19, 2024 4:07 pm
Your profile shows you have a 1925 TT, so I assume that is what you are asking about. Early TT's had a round tank, later TT's an oval tank, so the sediment bulb should not cause a fit problem for you. A round tank is higher and may pose a problem with the seat height of the cab. If you plan to install a Ford cab in the future you will need to use an oval tank, aftermarket cabs will be hit or miss.
Post by Allan » Thu Dec 19, 2024 4:10 pm
Photos of the fittings used would be a help advising you of a course of action. Non standard fittings may need more than usual remedies to make a fix.
Post by Original Smith » Thu Dec 19, 2024 5:37 pm
Does your tank still have the original flange at the bottom of the tank? If not, I would buy a different tank in good condition. I've paid $50-$100 for them.
Post by DanTreace » Thu Dec 19, 2024 6:08 pm
Use a wire hand brush or wire brush in power drill and clean well the area around the gas tank lower bung and that brass fitting. Then apply a very good penetrating oil (not WD-40). Let sit a while to do the work to soak down and around the pipe thread brass fitting, then wrench twist the fitting out counter-clockwise. The tank bung is soldered and riveted to the tank so it can take some twist without injury.
Post by Allan » Thu Dec 19, 2024 11:21 pm
We can only guess without knowing what kind of bushing is there and how it is fitted, size, thread, soldered, whatever!
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri Dec 20, 2024 12:35 am
As others have said, we need more information about the brass bushing; whether it is soldered in or just screwed in; and whether it has a hex shoulder on it, as a lot of brass bushings do. If it is not soldered in, and if it has a hex shoulder on it, you're in luck. As others have said, extreme care must be taken, even when just installing or removing the sediment bowl from the tank, much less, a brass bushing to keep from breaking the soldered seal between the tank and the outlet flange. If all else fails, when you have the brass elbow removed, if the bushing won't come out, you can take a hack saw blade and insert it into the threaded bushing and make 2 or 3 cuts through the bushing, being carefull no to damage the threads of the outlet flange.
suley
First Name: Suleman
Last Name: Ishaque
Post by suley » Fri Dec 20, 2024 2:53 am
Thank you for all the replies!
The car is a 1925 model T truck and not a TT. It seems like the bushing is threaded and no hex shoulder. The gas tank is round and fits under the seat in the current cab. Here are the pictures...
As always, really appreciate all the help.
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Post by Pat Branigan Wisc » Fri Dec 20, 2024 7:43 am
I have used internal pipe wrenches with good results. If it's stubborn carefully slit the bushing first
Post by speedytinc » Fri Dec 20, 2024 8:30 am
There is a broken PVC sprinkler pipe extractor tool that looks like a taper reamer.
Comes with 2 sizes of extractor ends. It will bite into your bushing.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Fri Dec 20, 2024 9:10 am
Pat has the solution, internal pipe wrench. Jim
Post by Mark Gregush » Fri Dec 20, 2024 9:27 am
My solution if not removing the reducer would be to add an inline glass bowl type sediment bowl with shut off and another shut off at the carb or find a sediment bowl that fits the thread now in the tank.
Post by Jerry VanOoteghem » Fri Dec 20, 2024 10:04 am
Here's a bunch of options... https://www.mcmaster.com/products/pipe-extractors/
This one is cheap & easy... https://www.mcmaster.com/products/pipe- ... d-parts-6/
I'll sometimes file four small corners for the edges of the tool to more easily grab.
suley
First Name: Suleman
Last Name: Ishaque
Post by suley » Fri Dec 20, 2024 12:55 pm
THANK YOU!
Love this list! Will try one of the ideas!
