FS NOS Eveready Mazda Bulbs in box
Post by TRDxB2 » Thu Oct 10, 2024 5:25 pm
All the bulbs are NOS & have dual tee-pee shaped filaments at equal heights as original. They are 6-8 volts and 21-21 c.p. & fit a headlight base socket. Boxes 1, 2 and 3 each have 10 bulbs with silver color base. Box 4 has 10 bulbs with brass color base over steel. Box 5 just 3 or 4 brass / steel base bulbs and box). I tested all the bulbs for proper continuity so they can be used. The c.p. isn't really bright enough for night time driving but could be good for a brake/tail light with appropriate socket & wiring. They make a nice display item.
Boxes 1,2,3 & 4 with their bulbs (old $35) new price $30 a box. Box 5 with four bulbs $15. Shipping extra.
BOX 3 SOLD
Re: FS NOS Eveready Mazda Bulbs in box
Post by TRDxB2 » Thu Oct 10, 2024 5:27 pm
more photos
The tee-pee arrangement of the filaments at the same height is the proper design for focusing in a Model T reflector by positioning each at the focal point of the reflector. Some modern tee-pee designs have one have filaments heights lower/higher to work with a different reflector design. The same is true for ones with a bar style filament.
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Post by jaybee47 » Fri Oct 11, 2024 9:01 am
Frank. I'd like to buy box 3. I'll PM you.
Post by TRDxB2 » Fri Oct 11, 2024 1:53 pm
You got them!
Post by TRDxB2 » Fri Oct 18, 2024 11:05 am
switch on light me up
Post by TRDxB2 » Fri Nov 22, 2024 11:30 am
bump da bump
Post by TRDxB2 » Wed Jan 01, 2025 5:20 pm
bump........................
Post by TRDxB2 » Wed Mar 05, 2025 8:24 pm
bump .............
Post by TRDxB2 » Fri Mar 14, 2025 8:51 pm
In case your missing a bulb
Post by TRDxB2 » Mon Apr 07, 2025 9:12 pm
bumppppppppp
