Rear main adjusting with a 3 dip pan
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Sat Jun 22, 2019 11:52 pm
I'm thinking about taking some main shims out and was wondering if there are any tricks to get at the rear main cap in my '21 with a 3 dip pan. I've done this many times,but always had a 4 dip pan. Thank's : Bruce
SurfCityGene
First Name: Gene
Last Name: Carrothers
Re: Rear main adjusting with a 3 dip pan
Post by SurfCityGene » Sat Jun 22, 2019 11:59 pm
I've taken a shim out of the 4th rod but don't think you can access the rear main. The rod was tricky enough and I have good hands for tight work. Make sure you stuff plenty of numbered rags in if you go there!!
1912 Torpedo Roadster
Kerry
Last Name: van Ekeren
Post by Kerry » Sun Jun 23, 2019 1:41 am
Like Bruce has posted, hard enough just to do #4 rod let alone take 2 fly wheel bolts out to drop the cap, and re-wire etc,
maybe some has done it, would sure like to know if possible.
Kerry
Post by Kerry » Sun Jun 23, 2019 1:42 am
Sorry, as Gene has posted. :o
