Buying or making a pin to secure fan crank shaft pulley
Dave_Kriegel
First Name: David
Last Name: Kriegel
* REQUIRED* Type and Year of Model Ts owned: 1927 1926
Post by Dave_Kriegel » Sun Jun 23, 2019 10:25 am
My pin fell out and is lost Looking in Snyders and MAcs I see the entire assembly for sale but not just the pin Am I blind or does someone see where I can buy just the pin? Another member suggest I fabricate a pin drilling a hole in it I need advice on finding a soft metal of the correct diameter He then suggests using a split pin to secure the fabricated bolt I assume I drill a hole down into the bolt face the length of the bolt to expand it and not through the bolt. Sorry for my ignorance I keep trying to learn from all of you This is a non starter car
First Name: Dallas
Last Name: Landers
Re: Buying or making a pin to secure fan crank shaft pulley
Post by Dallas Landers » Sun Jun 23, 2019 10:34 am
Dave, let me look see if I have one. If I do you can have it. I am close so you could pick it up if you luke.
First Name: Dallas
Last Name: Landers
Like not luke.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Jun 23, 2019 10:41 am
I have a crank pully pin. You can call or txt me.
260-336- six 55 five.
Post by Steve Jelf » Sun Jun 23, 2019 11:04 am
This is not in great condition, but it shows how the pin goes. The pulley has a small hole on one side to drive out the pin with a drift, and a larger opposite hole for the pin to pass through. The end of the pin near the larger hole gets a cotter pin, not a roll pin, to keep it in.
Last Name: Strange
Post by CudaMan » Sun Jun 23, 2019 11:16 am
Dave_Kriegel
First Name: David
Last Name: Kriegel
Post by Dave_Kriegel » Sun Jun 23, 2019 11:42 am
Thank you all !! This is why I like repairing and learning Model T's Where else can I put a question out on a Sunday Morning and get so much help and advice in just a few hours !!!! :D
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
Post by BE_ZERO_BE » Sun Jun 23, 2019 2:13 pm
I use a roll pin.
It eliminates the need for a cotter pin which is difficult to install and remove.
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
Post by DanTreace » Sun Jun 23, 2019 6:50 pm
Prefer to use the solid Ford style pin in the crank pulley.
Once had trouble removing a rolled pin, guess the former owner stood on the crank handle at some point. The crank handle ratchet wouldn’t fit well, as that hollow roll pin bent. Sure was hard to get that bent piece of metal out the pulley holes :(
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Sun Jun 23, 2019 8:53 pm
Must have been a Left Hand Metric Roll Pin :lol:
I have had good luck installing and removing the roll pin on mine.
A roll pin came with the after market machined crankshaft pulley I got some time back.
Be_Zero_Be
Post by Original Smith » Mon Jun 24, 2019 9:42 am
If your new pin isn't secure in the crank, you might wish to knurl the center of it so it will be snug in the crankshaft.
