]Looking to see if there is enough interest in getting another batch of PASCO wheel casting made.
First photo shows the castings.
They require machining (your machinist) :
- to match the wheel nut (left hand thread)
- hub cap (right hand thread)
- 6 wheel bolts
This will be done at an Amish foundry in ductile cast iron.
2nd photo shows the threaded wheel center custom matched to the nut and cap 3rd photo.
Tentative price is in the $90+ range, probably higher as foundry work has gone up the last couple of years.
Pickup at Hershey, Chocolate field.
Thanks Kevin
						PASCO Wire Wheel Center Unmachined Castings Hershey Delivery
amesbuilt
- First Name: K
- Last Name: Mowle
- * REQUIRED* Type and Year of Model Ts owned: Ames Model 814 Speedster, Peerless barn find Speedster
Re: PASCO Wire Wheel Center Unmachined Castings Hershey Delivery
Photos
1- castings
2- threaded hub
3- brass hub cap and nut
						1- castings
2- threaded hub
