Refractory Brake Rod
TillieTheTouring
First Name: William
Last Name: Naquin
* REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Post by TillieTheTouring » Sat Sep 13, 2025 12:17 pm
I went to tighten my hand brake because it has too much play in it. I watched a video of a picturesque Australian performing this task. He took out the pin, loosened the round cyllinder-screwy thing, then adjusted the nut so he could rotate the yoke on the end. But my cylinder thing is both frozen in place and just about fully retarded. Im looking for a solution. I was thinking to purchase a blow torch, loosen the screwy thing with it, then cut down the screwy thing so I'd have more adjustment room on the rod- but I figure I'd better get some advice here first. Thanks!
Re: Refractory Brake Rod
Post by Scott_Conger » Sat Sep 13, 2025 12:30 pm
advice: never handle power tools without calling 911 first
Tadpole
First Name: Tad
Last Name: Glahn
* REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Post by Tadpole » Sat Sep 13, 2025 12:43 pm
We need to identify the screwy thing first. Are you talking about emergency brake rods and the threads at the end of them that the clevis and nut are on?
Post by TRDxB2 » Sat Sep 13, 2025 1:08 pm
I am assuming your referencing the hand brake rods not the clutch & not the slow speed clevis attached to the Clutch Pedal
Your description makes it sound like the brake rod is to long if you need to cut off the end in the clevis (screwy thing ?) for adjusting.
The parts book indicates left and right rod. The rods also have a bend to clear the radius rod. Your rod may have lost the bend making it longer.
To loosen the clevis, remove the rods, clean the threads you can get at, put penetrating oil on the nut & clevis. Be patient may take several application & a few days. If you need heat & have a gas stove, send your wife out on an errand...... :?
Post by RajoRacer » Sat Sep 13, 2025 1:25 pm
First, remove the entire brake rod - if have access to a torch, heat up the clevis and let cool - it will loosen right up - same with the nut. You can also thread more of the rod, if needed with a 5/16 fine thread die.
Last Name: Hatch
Post by Dan Hatch » Sat Sep 13, 2025 1:33 pm
If you don’t have a torch an induction heater may be a been choice for you.
Might be easier to use and safer.
modeltspaz
Last Name: Spaziano
Post by modeltspaz » Sat Sep 13, 2025 1:47 pm
What "Tillie the Touring" failed to mention, among other things, is what year "Tillie" happens to be. If Tillie is an Improved Model with a big drum rear end, there may be lined brake shoes in the drums. There may even be accessory lined shoes on an earlier rear end.
If the emergency brake shoes are lined, it may be a case of worn emergency brake linings. Shortening the brake rods may be just a band-aid fix. If you have a big drum rear, check the linings too.
Post by Original Smith » Sat Sep 13, 2025 3:11 pm
Something that would benefit all of us is to use proper terminology!
Post by Norman Kling » Sat Sep 13, 2025 3:38 pm
Be sure that you don't get them too tight. The lever also puts the car in neutral and should be in neutral with the lever approximately straight up. Then when you pull it back it should go a few notches before it applies the parking brake. Otherwise you will not be able to use the neutral with the lever. It is actually much better to use the lever to hold in neutral when waiting at a signal because the foot is unstable and might be slipping the low drum or the clutch disks, but the pedal will be set for the best neutral position.'
Also if the adjustment is too long, it will prevent you from going into high gear with the lever all the way forward.
Post by speedytinc » Sat Sep 13, 2025 4:46 pm
Start with a look @ the service manual. Get the part names correct.
After reading the OP several times, I have no idea what the problem or area is that needs a fixin.
Post by Allan » Sat Sep 13, 2025 6:06 pm
The later clevises are rolled steel, with a seam along them. Attention with a hammer around the outside of the clevis, as well as heat, should free them up. Failing that a sharp chisel can be used on the seam to open up the clevis a tad.
I agree, get your terminology up to speed will get you more accurate advice.
Post by Jerry VanOoteghem » Sun Sep 14, 2025 8:37 am
What's a "refractory brake rod"? I have no idea whatsoever what this thread is about...
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Sun Sep 14, 2025 8:42 am
Mr. VanOoteghem, anything relating to a T is refractory by nature.
TillieTheTouring
First Name: William
Last Name: Naquin
Post by TillieTheTouring » Sun Sep 14, 2025 10:58 am
I'd love to show you pictures of the assembly in question, but I can't figure out how to load them
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Sun Sep 14, 2025 12:49 pm
There are instructions for attaching photos in the Forum Support section.
