Generator gear installation
Topic author - Posts: 1945
- First Name: Robert
- Last Name: Jablonski
When fitting a gear on the generator, with the key in place and retaining pin in place before peening , , how much clearance is acceptable to eliminate gear wobble ?
- Last Name: Golden
Re: Generator gear installation
What you really have to be careful of is to make sure you slide the Bendix on without popping that key out the back and into your transmission.
