What if your timing is at 7.5% instead of 15%?
Last Name: Hjortnaes
Post by DHort » Thu Oct 23, 2025 3:16 am
Does it make the car go slower?
Does it make the car burn gas faster?
Does it make the car harder to start?
Does it affect the amount of advance you can do with the spark lever?
The world wants to know.
Re: What if your timing is at 7.5% instead of 15%?
Post by Allan » Thu Oct 23, 2025 7:13 am
I must be out of this world! Who'd have thunk it?
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Oct 23, 2025 8:00 am
DHort .... TIMING IS MEASURED IN DEGREES, NOT PERCENTAGE
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Thu Oct 23, 2025 8:52 am
Dave,
Camshaft design is a science I leave to ones with more experience than me but I do know some things.
Massive numbers of tests, time, and money has been spent on this but it is extremely difficult to find real head to head testing.
To scratch the surface of Model T cams see this: https://mtfctulsa.com/Cams/index.html
EVERY camshaft design is a compromise between many conflicting factors to produce the best profile for a certain setup at a certain RPM range.
I prefer use the experience and advice of ones with more experience than me.
I talk to owners of cars and ask them their setup and watch their performance to determine what I do to my setups. And my setups are sometimes different depending upon the intended use of the vehicle.
There are a lot of things that matter and it is not just timing.
Here are a few design factors and I am sure there are a lot more.
Desired RPM range, Desired engine smoothness, Desired fuel economy and emissions, Desired Power, Desired valvetrain life, Lift, Maximum size that will actually fit in the engine, Overlap, Ramp angles and profile, Intake open and close angle, Exhaust open and close angle, Size / type of the lifter, Valve spring strength, Spring bind height, Weight of the valve train, Size of the valves, Angle of valve seats, Size of the engine (Cubic Inches), Type of engine (flat, F, overhead) / flow path design, Exhaust system restriction, Carb size / flow design, Normally aspirated vs turbo vs charger, and more.
All of this is based on the theories that two objects cannot occupy the same space at the same time and the metal parts and gasses take time and energy to start and stop at a maximum rate and top speed.
The engine RPMs change but the maximum acceleration rate does not - This is also why we advance the ignition timing as the speed increases.
Some modern engines use variable valve timing and advance the cam as engine speed increases showing how important cam timing is.
Some factors are very important like it has to fit and some not so much until you cross a line, think valve float or bind damage.
Some factors are very difficult to change like port design and the head gasket shadowing the valves.
The camshaft is only one part of a balanced system that ALL needs to work together. The biggest bang for the buck is to fix the most restrictive portion of the system and improve that. Think, a massive cam will not fix a restrictive carburetor or one that is not efficient at the desired flow rate.
Also think it is all a balanced system and all has to work together.
Advancing the camshaft will generally improve High RPM performance but will reduce Low RPM performance, what speed do you want to run your engine.
Advancing the camshaft will burn more fuel if you decrease the engine efficiency, cause parasitic losses, or just run harder (faster). The fuel burn rate is determined by engine efficiency and how much air/fuel is pushed through. The throttle position and load is the biggest variable.
Advancing the camshaft may effect ease of starting if it makes it inefficient or has the valves open at the wrong times like intake open when it sparks at starting speed. Briggs and Stratton engines have an easy starting feature to adjust the valve timing to make them easier to start.
Ignition is directly effected by camshaft timing BUT when you time the engine ignition it negates and resets it.
The amount of ignition advance is fixed mechanically in a Model T Ford by lever lengths and wear conditions of all the joints.
The total ignition advance angle to piston will change if the base (starting) timing is changed or the lever lengths or the slop in the joints changes.
You have almost complete control over ignition timing with the left lever on the column so this is a less important factor.
Put the lever where it is most happy and have a nice drive.
Does bad ignition timing make the car slower - Yes
Does bad ignition timing make the car burn gas faster - Yes. Anything that makes the car less efficient will make it burn more gas.
Does bad ignition timing make it harder to start - Sometimes. It is tolerant until it crosses the TDC line or is way too late.
I set my spark timing @ 1/8" down (after TDC) lever up on T's and A's (same as the 3rd notch method) with the lever all the way up. I also verify that I get full timing advance without excess slop, binding, or wear.
It is degrees and not precent.
You also did not specify camshaft or ignition timing, your last question implies cam timing.
Part of the world might want to know but I would like to see real life head to head tests and numerical data with various setups.
More tests like the Tulsa Cam Project expanded.
The effects of cam timing on a SB Chevy are next to useless on a Model T.
Post by TXGOAT2 » Thu Oct 23, 2025 9:23 am
Ideally, valve timing, lift, and duration would be variable according to engine speed and load. Camless engines may be in the future, with valves operated by some sort of solenoids or hydraulic actuators under computer control.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Thu Oct 23, 2025 9:39 am
I’m guessing the original poster opted for the percent symbol because the superscript “o” doesn’t lend itself to a lot of keyboards.
Tom Miller
Post by TXGOAT2 » Thu Oct 23, 2025 11:44 am
I use "deg."
Post by DHort » Thu Oct 23, 2025 12:34 pm
Moxie
It was 1AM when I typed it, so I guess % was on my mind. Must have been thinking of tariffs.
Mike, thank you for all that info.
Post by Jerry VanOoteghem » Thu Oct 23, 2025 1:43 pm
Moxie
I think we all knew what you meant Dave :)
Ron Patterson
First Name: Ronald
Last Name: Patterson
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout
Model T Ford Initial Timing Spark etting
Post by Ron Patterson » Sat Oct 25, 2025 2:21 pm
I believe the more important question is “why did Ford select the initial timing of 15.5 degrees after top dead center for the Model T”?
At the time most low-priced automobiles utilized dry cell battery powered trembler coils for ignition. Keeping the batteries serviced was a constant problem and if the owner did not carry spare batteries getting stranded was a common problem
For this reason, when the Model T car was first developed, Henry Ford insisted it have a self-contained power source for the engine ignition system. Now batteries would be required. Ford’s solution was an independent internal ac generator to supply power to the coils. This was a revolutionary feature for low priced automobiles at that time.
Twenty years ago, Steve Conff and I, for different reasons, became interested in the details of the Ford ignition solution and its functional details. As an ac power source, we knew it produced a current pulse every 22.5 degrees of crankshaft travel. But how exactly were these current pulses controlled to produce ignition at the precise time for starting and running an internal combustion over its full range of operation?
Attached is a copy of an article we co-wrote to help simply explain and understand how the Model T Ford ignition and spark timing technically worked. The most interesting thing was how the magnets were positioned on the flywheel to create current pulses for easy hand cranked starting (batteries did not appear in Model T’s from the factory until 1919) AND provide appropriate spark timing for operating the engine over its full RPM range of normal operation.
You can make a Model T run using different initial timing settings from Fords, but there will be tradeoffs if you make changes to the original system. Then you can figure out how your changes will affect the car’s operation.
Ron Patterson
Model T Ignition System-Final Article.pdf
(388.82 KiB) Downloaded 60 times
Ron Patterson
First Name: Ronald
Post by Ron Patterson » Sat Oct 25, 2025 5:33 pm
Can anyone direct me to an electronic copy of this article: “Edward’s Huff, Henry Ford and the Flywheel Magneto”, The Vintage Ford, Vol. 31, Number 2 (March/April, 1996)
Ron Patterson
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Oct 25, 2025 5:52 pm
I have always set timing by a vacuum to optimize fuel efficiency. Simple with a vacuum port, set to the highest HG psi and back off 1 psi at idle. What ever is your octane level you just hit the sweet spot. If you ever wonder why some T intakes have a drilled port...., now you know. Science does not lie but politicians do!
Post by Allan » Sun Oct 26, 2025 4:02 am
Henry, that reminds me of a saying my Dad often used. "Figures don't lie, but liars can figure!"
