Roof overhead update
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Sun Mar 01, 2026 5:38 pm
I just got the head back the machine shop this week. The head got 8 new valves, 2 new valve guides and 6 bronze inserts. There is a serial number on the front of the head and it is 1077 X. There is freeze plug on the top of the head that has some number but are pretty hard to read
Fitz
Joe Bell
First Name: Joe
Last Name: Bell
Re: Roof overhead update
Post by Joe Bell » Sun Mar 01, 2026 8:19 pm
You will love how it performs!
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Post by Dodge » Mon Mar 02, 2026 2:04 am
Hey Ralph,
How rusty were those vavle springs before everything was cleaned up? Valve springs tend break when they've been rusted and pitted.
just say'n....
Post by TXGOAT2 » Mon Mar 02, 2026 12:36 pm
I would not run those valve springs. Even a single small rust pit, nick, or scratch can cause a spring to break in service, possibly leading to a dropped valve.
Post by Scott_Conger » Mon Mar 02, 2026 12:46 pm
I am really glad someone spoke up about the valves - overheads are beyond my experience and expertise, but I do know metal and was hoping someone with conviction would step in.
Ralph F
First Name: Ralph
Post by Ralph F » Wed Mar 04, 2026 9:47 pm
Thanks fellows for pointing out to me that I need to replace these valve springs. Would you be able to recommend who
I should contact for replacement springs. Again thanks for the advice.
Fitz
Post by Scott_Conger » Wed Mar 04, 2026 9:58 pm
Ralph
my go-to supplier of springs:
https://www.leespring.com/compression-springs
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Mar 05, 2026 12:21 am
Just a FYI- regular music wire springs do not have the fatigue resistance needed for an application like this. You really need a spring made of a material suited for use as a valve spring. The challenge will be finding one with wire small enough wire to keep the seat pressure around 50-60 lbs.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Mar 05, 2026 12:48 am
The stock T valve springs are working fine in my Akron-Hed overhead. Chebby valves and keepers, and 8N tractor spring retainers are a perfect fit. I went looking for off the shelf valve springs last year for a Fronty, and found that all the light pressure options had been discontinued… :roll:
Post by Scott_Conger » Fri Mar 06, 2026 10:12 am
Dan
thank you for info regarding music wire. I've never given it any thought at all regarding valve springs since my spring requirements are typically all carburetor or die-stamping applications. Never too old to learn something new :)
Now I had to do some research, and it does turn out that Lee Spring does in fact sell chrome silicon springs suitable for valve springs. Since I'd never had a need to purchase such a product, their alloy springs were news to me as of this AM. Whether or not they actually carry something that would be appropriate in this application, I haven't a clue...
Hopefully, Ralph will find the right spring for the application soon.
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Fri Mar 06, 2026 1:20 pm
I always go to SBI. You can download a PDF. Starting on page 1083 (springs). You will need information from your spring. Takes some time but if they don’t have it l would be shocked. They have all things for overheads. I have used them for Roof, Rajo and Fronty heads
Jahn_Wright
First Name: Jahn
Last Name: Wright
Post by Jahn_Wright » Fri Mar 06, 2026 2:12 pm
Jahn
1925 Coupe--owned by my Grandfather
Dodge
First Name: Dodge
Last Name: Riedy
Post by Dodge » Fri Mar 06, 2026 4:58 pm
Another good source is: Diamon wire spring company. You can download their catalog for stocking springs or have them custom made.
Dodge
Post by Mark Gregush » Mon Mar 09, 2026 10:20 pm
John thanks for posting that link. I was trying to think of the name of the company/catalog I spent hours looking at trying to find valves for my Chevrolet overhead conversion.
Ralph F
First Name: Ralph
Post by Ralph F » Tue Mar 10, 2026 8:19 am
Again gentleman thanks for the good information.
Fitz
David Greenlees
First Name: David
Last Name: Greenlees
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
Post by David Greenlees » Tue Mar 10, 2026 9:15 am
Fitz, It's good to learn that you are still involved with Model T speed equipment. Haven't seen you in over 40 years and hope that this Roof head works out well for you. If you are ever headed down here, you are more than welcome to visit the shop and see more T racing equipment and kick tires.
