Buzz Saw Govenor Design
Topic author - Posts: 257
- Last Name: Kemp
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT Tow Truck
Hi, I am trying to get all of the parts to put a Buzz Saw together. I have a Buzz Saw Table, with guard, 24" Blade, and a power pulley for my T engine. But now I was told I will have to get/buy/design and make my own Governor. I have looked on the web and have nit be able to find any designs for the Governor. So I thought I would ask this question on our Forum? Thanks Rich Kemp (937) 999-9990
- First Name: dale
- Last Name: doubleyou
Re: Buzz Saw Govenor Design
At 4:38 in this Model "T" buzz saw video, a simple governor appears, but I'd watch the whole thing!
https://www.youtube.com/watch?v=2LMv_Y4axYw
That is a very nice presentation. I found a similar one in the '60s but couldn't talk them out of it.
- Last Name: Andreasen
- * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
That's an air governor, same principle as used on Briggs and Stratton engines for years. A simple, light pivoted "paddle" is struck by the fan air stream. If the stream slows down (load on engine) a spring pulls the fan forward and pulls the linkage to the throttle, speeding up the engine. As the air stream picks up again, the paddle is prevented from going too far by a second spring, so the rpm is maintained. In other words, it's all a "balancing act" between the two springs. Changing the amount of pull on the springs via threaded rods controls the minimum/maximum speed of the engine.
You can probably find a better explanation and diagrams on the internet. Just Google "air governor".
- Last Name: Hatch
You need a Kingston Governor. Used of a lot of farm equipment. Replaces the generator. I think I have one, maybe parts of 2. PM me if you are interested. Dan.
- First Name: Jack
- Last Name: Murray
- * REQUIRED* Type and Year of Model Ts owned: 1926 light express
I've seen photos and plans posted on here before on building homemade governors from old generators; check here for starters:
http://www.mtfca.com/discus/messages/17 ... 1300190691
- Last Name: Kemp
Thanks Yukon Jack, I will try this design out, and see what happens. Rich
Keep your eyes on Ebay, they come up every so often. I think there was just one on, the type that replaces the generator.
Found it;
https://www.ebay.com/itm/1913-1927-Mode ... ctupt=true
Found it;
- First Name: Hal
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: '22 TT Stake Bed, '18 Touring (Hers)
I am totally shocked. I cannot believe some of the safety nuts have not chimed in to let us all know how dangerous this thing is.
"I have a Buzz Saw Table, with guard, "
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
The bottom governor is made with two generator face plates.
