New forum LINKS
ChrisB
First Name: Chris
Last Name: Brancaccio
New forum LINKS
Post by ChrisB » Mon Jan 21, 2019 4:13 pm
We are now picking up the stragglers from the old system, the users that only post a few times a year.
This is posted on the old 2018 Forum on the 2019 Forum link.
This link will take you to new forum software.
YOU WILL NEED TO RE-REGISTER ON THE NEW SITE.
Your old user name and password will not work there.
You may have to use a different user name if someone has used it already.
Click here to go to register on the NEW FORUM Register
ucp.php?mode=register
Click here to go to LOGIN to the NEW FORUM Login if already Registered
ucp.php?mode=login
Click here to go to VIEW the single 2019 FORUM 2019 Forum
viewforum.php?f=2
Click here to go to VIEW ALL the NEW FORUMS ALL Forums
index.php
You should save these links in place of any old links you have to make sure you have the correct ones. Notice they all start with https:
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Marv K
First Name: Marv
Last Name: Konrad
* REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
Board Member Since: 2010
Re: New forum LINKS
Post by Marv K » Tue Jan 22, 2019 12:46 am
-Chris-
The question is also likely to be asked: "How do I reference/find something from the pre-2018 Forum threads?"
Thinking of reference information and knowledge. Thanks.
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
ChrisB
First Name: Chris
Re: New forum LINKS
Post by ChrisB » Tue Jan 22, 2019 10:26 am
If you go to Board Index at the top there is a link to 2018 Forum.
If you want to search the old forums your best best is still Google
Example search
5 ball carburetor site:www.mtfca.com
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Oakknoll
First Name: William
Last Name: Crogan
* REQUIRED* Type and Year of Model Ts owned: 25 TT, 25 touring, 27 pickup,13 runabout
Re: New forum LINKS
Post by Oakknoll » Tue Jan 22, 2019 2:16 pm
google can not find the new forum
Duey_C
First Name: Duane
Last Name: Cooley
Re: New forum LINKS
Post by Duey_C » Wed Jan 23, 2019 1:16 am
duckduckgo.com has it in the second spot Oak. Good to go. Hope that helps a trifle.
I typed in mtfca forum in the search window and... Cake, or piece of. :-)
