Sept Oct Vintage Ford
got10carz
Topic author - Posts: 579
- Last Name: Meixner
Is it just me, or is the technical article on page 12 worded wrong. Read the 3rd paragraph starting with FOR STARTING PURPOSES, worded wrong.
RalphS
- First Name: Ralph
- Last Name: Sullender
- * REQUIRED* Type and Year of Model Ts owned: 21 tt
Re: Sept Oct Vintage Ford
Before is after and after is before as I understand it .
Around and around we go and where we stop we check the gas oil water and tires.
jab35
- Last Name: Bartsch
Starting with timing set 5 degrees before tdc could break an arm or Bendix. Too bad peer review happened after publication. Hopefully a correction is printed in the next issue, the article is excellent otherwise. jb
got10carz
I messaged Mike. He said the next issue will correct the issue.
Dennis_Brown
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
I am trying to figure out what the pictures inside the front cover are. Maybe my glasses need adjusting for magnification.
