Weight of bare chassis
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Post by John E. Guitar » Fri Oct 18, 2019 2:12 am
Does anyone know how much the chassis weighs on a 26/27 Model T?
I can find info on a running chassis, i.e. a car without a body but nothing on the bare chassis (no engine, transmission, axles etc).
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: Weight of bare chassis
Post by mtntee20 » Fri Oct 18, 2019 7:52 am
John,
I do not know the exact weight but I can stand between the rails, pick ours up, and easily walk with it. Bare frame with running board brackets and brake quadrant. I would guess between 50 and 75 pounds but that's just a guess. It might be as much as 100 lb. It's more awkward than anything else.
Good Luck,
Terry
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Oct 18, 2019 8:58 am
1922-23 chassis weighs 1080 lbs acording to the encyclopedia
Post by Mark Gregush » Fri Oct 18, 2019 11:30 am
Might be easier to ask if anyone know how much just the bare Model T frame weighs. If you are looking to have one shipped, it could be the size more then the weight that would give you the cost. Add onto that if or if not the running board brackets are attached.
Last Name: Hjortnaes
Post by DHort » Fri Oct 18, 2019 12:09 pm
Would not a chassis be defined as a complete car that is just missing a body? Frame, axles, wheels, and motor.
Post by John kuehn » Fri Oct 18, 2019 1:03 pm
I have always understood the chassis usually means a frame with wheels, engine, transmission and differential. It seems that way to me anyway.
mtntee20
Last Name: Miller
Post by mtntee20 » Fri Oct 18, 2019 4:07 pm
The topic author stipulated: No engine, transmission, axles, etc. I would take that to mean a bare frame.
aDave
First Name: David
Last Name: Dufault
Post by aDave » Fri Oct 18, 2019 4:45 pm
So, when we tire of type of oil to use, kind of transmission bands to use, waterpump or no, we can talk about the differences between chassis, rolling chassis and frame...no?
Wikipedia sets the tone with these two definitions....(prelude to the coming cabin fever season):
An example of a chassis is a vehicle frame, the underpart of a motor vehicle, on which the body is mounted; if the running gear such as wheels and transmission, and sometimes even the driver's seat, are included, then the assembly is described as a rolling chassis.
OR
What is difference between frame and chassis?
A chassis is the skeletal framework of a vehicle on which most of the mechanical parts like tires, axle assemblies, steering, brakes, and the engine are fastened. ... A vehicle frame, on the other hand, is the main structure of the chassis. All the other components, including the chassis, are fastened to the frame.
aDave
First Name: David
Last Name: Dufault
Post by aDave » Fri Oct 18, 2019 4:49 pm
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Fri Oct 18, 2019 4:51 pm
So, what John should have asked for is the weight of the frame since the chassis is obviously much heavier due to having more components than a frame I think …..
Oh wait. I have something else to do! 8-)
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Fri Oct 18, 2019 5:37 pm
Weight of a bear chassis - variable. Black bears weigh anywhere between 90 to 600 lbs. Grizzlies can weigh over 1,000. Bare bear chassis ? Bare bones, figure 12 - 14 % of live weight.
"Get a horse !"
Post by TRDxB2 » Fri Oct 18, 2019 5:51 pm
A '26 chassis without out engine, axles etc is about 50 -75 lbs else I couldn't left it up.
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Fri Oct 18, 2019 9:33 pm
Thanks guys, the 50-75 lbs figure is what I was looking for.
Altair
First Name: David
Last Name: Menzies
Post by Altair » Wed Oct 23, 2019 1:43 pm
Pick up the frame and stand on your bath scale subtract your weight and walla.
