Differential casting block letters
				Jeff Hood
- First Name: Jeff
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
Cleaning up a differential casting and found block letters instead of usual Ford script. Has anyone seen this or is this a "spurious" part?
				R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
Re: Differential casting block letters
Some genuine Ford parts did have block letters instead of the script. The crank ratchet is one place that that was common.
