1925 pickup bed wood dimensions
				SleepyT
- First Name: Russell
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring, 1914 roadster, 1913 roadster
Does anyone have the wood dimensions for an original 1925 pickup bed that they would be willing to share?
				Afrazer
- First Name: David
- Last Name: Frazer
- * REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Re: 1925 pickup bed wood dimensions
Are you referring to a steel factory bed or a whole wood bed
									1925 closed cab TT
1926 two door sedan
1926 two door sedan
				SleepyT
Factory ford steel bed
				Afrazer
- First Name: David
- Last Name: Frazer
I used 26-27 wood dimensions I just didn’t account for the plate in the middle of the bed as that was not original for a 25 steel bed. Bed wood dimensions are similar to 26-27.
									1925 closed cab TT
1926 two door sedan
1926 two door sedan
				Afrazer
- First Name: David
- Last Name: Frazer
This is the blue print I used
									1925 closed cab TT
1926 two door sedan
1926 two door sedan
				Afrazer
- First Name: David
- Last Name: Frazer
And this is how it turned out when I was done that night
									1925 closed cab TT
1926 two door sedan
1926 two door sedan
				SleepyT
Thank you very much. I found that diagram also but wasn’t sure the dimensions were the same for 25 and 26-27. Your bed looks great.
				Afrazer
- First Name: David
- Last Name: Frazer
Thank you Just like the rest of truck it’s looks good in pictures but It’s not no show truck
									1925 closed cab TT
1926 two door sedan
1926 two door sedan
				Afrazer
- First Name: David
- Last Name: Frazer
Do you have 25 bed strips. They are different from 26-27. I ended up using 26-27 after a few years of looking just so I can have a complete looking bed but if I ever get ahold of 25 bed strips I redo it
									1925 closed cab TT
1926 two door sedan
1926 two door sedan
				SleepyT
Yes, I do have the original 25 strips. It’s a pretty correct truck. We are restoring it for my 17 year old son. The bed is painted and the wood is our winter break project. Thanks again and happy holidays!
				Afrazer
- First Name: David
- Last Name: Frazer
Awesome sounds like a good deal mine was not complete and I have been pieced it together for the last years and still not done. But such an awesome project for you guys. Merry Christmas happy new year
									1925 closed cab TT
1926 two door sedan
1926 two door sedan
