Steering column and control rods
Topic author - Posts: 732
- First Name: Danny
- Last Name: Deaton
Trying to figure out how to remove the rods. Don’t tell me all I need to do is bend these ears?
Re: Steering column and control rods
If you anneal the ears they will bend easier with less chance of breaking.
- First Name: Danny
- Last Name: Deaton
The gear box looks like one piece?
So bending them is the way it’s done?
If so,yes I will anneal
- Last Name: Strange
- Board Member Since: 2013
Since you have the later single piece gear case, yes, you have to bend the ears (after annealing them so that they don't break).
Folks with the earlier two-piece gear cases could grind off the rivets holding the two parts of the case together and slide the rods out without bending the ears.
http://www.mtfca.com/discus/messages/70 ... 1493740470
http://www.mtfca.com/discus/messages/82 ... 1531404752
- First Name: Danny
- Last Name: Deaton
K
Thanks guys
Thanks guys
anneal, let it cool to room temp, bend a very little bit...repeat a lot of times
multiple annealings followed by thorough cooling during the process is mandatory, in my experience. It takes very little material movement for the metal to become very brittle again.
- First Name: Danny
- Last Name: Deaton
Cut the rods off. Going to clean this stuff up. Sandblast the rust and then anneal
- First Name: Danny
- Last Name: Deaton
I love bringing this stuff back to life
- First Name: David
- Last Name: Menzies
- Board Member Since: 2012
To anneal a non-ferris metal, copper, brass, bronze heat to cherry red and quench in cold water, non ferris is hardened by cooling over long periods of time, the longer the harder. Non ferris will work harden and may require to be re-annealed during the working process. Iron is the opposite process, except will also work harden, they call it metal fatigue.
- First Name: Danny
- Last Name: Deaton
We take brass sheet and anneal it so we can beat it into a buttplate for flintlocks. Easy to work but like you said, starts to harden back up after you work it.
Good that you are acquainted with working brass. Just know that you're used to working with brass that is alloyed for what you're doing, and this has a very different grain structure than you're used to. It will kick your butt if you're not careful. Knowing brass gives you a leg up but be careful to not get cocky! You'll be fine if you go slow.
I assume you have a better pair of control rods to use?
- First Name: Danny
- Last Name: Deaton
Yes, new set of rods and all the small parts. I will post more pics as I progress
