question for those who have actually adjusted valves
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post by thom » Wed Jan 29, 2020 9:25 pm
For those who have adjusted valves in a T with adjustable lifters, have you found that the 10 degrees per turn of adjustment gets .001 adjustment to be true? I'm curious. I suppose only if the lifter is threaded 3/8x24 tpi ? Knowing that would make things a little quicker once you determine approximately how much gap you need to close up, wouldn't it? :?:
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Re: question for those who have actually adjusted valves
Post by Gene_French » Wed Jan 29, 2020 9:55 pm
Tommy:
I use the "3" wrench adjustable lifters … I will set the locking nut against the lifter body to effect a slight resistance when turning the adjustment screw … this eliminates or atleast reduces any movement when locking the adjustment … and yes , using the thread pitch like a micrometer is a good way to set the clearance ...BUT , as with any setting operation you must check and re-check your work … always an optimist ...Gene French
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Wed Jan 29, 2020 10:28 pm
Just curious. Do youse guys with adjustable lifters set them hot ? I’d guess not since gap is specified for the stock non adjustable lifters. Prolly not that critical.
"Get a horse !"
jab35
Last Name: Bartsch
Post by jab35 » Wed Jan 29, 2020 10:49 pm
For 24 pitch, one turn = 0.0417", 1/36 of a turn 0.001157" so yes, 10 degrees of rotation is just over one thou, if that is still the question, best,jb
