snowbird parts info
Oakknoll
First Name: William
Last Name: Crogan
* REQUIRED* Type and Year of Model Ts owned: 25 TT, 25 touring, 27 pickup,13 runabout
snowbird parts info
Post by Oakknoll » Fri Jan 31, 2020 3:43 pm
need info on plate under radiator that anchors tension rods, size and shape.
this is for 1926 mailman special
send private message for photos
RodellJunior
Last Name: Rodell
Re: snowbird parts info
Post by RodellJunior » Mon Feb 03, 2020 9:57 pm
William,
Here is a drawing showing the parts of the Snowbird. The plate you are referring to is trapezoidal and replaces the bar under the front spring clamp. It should be easy to have one laser cut from 1/2" steel. I would love to see pictures of your Model T snow machine.
Jim
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Post by Jim, Sr. » Tue Feb 04, 2020 9:54 pm
If you "click" on the drawing it will enlarge. Do it twice to enlarge twice.
1922 Coupe , 1926 Touring
Oakknoll
First Name: William
Last Name: Crogan
Post by Oakknoll » Mon Feb 17, 2020 10:51 pm
would like to see just what this front plate looks like for a better copy, any idea where there might be one to look at?
Hodag88
First Name: Kevin
Last Name: Bruso
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
Post by Hodag88 » Thu Feb 27, 2020 1:35 pm
I sent you an email regarding this part....
