Fed-Ex!!!! How *could* you!
Topic author - Posts: 45
- First Name: Robert
- Last Name: Frankel
...I thought I’d hit the jackpot when a member sent me a PM that a set of top irons for my ‘26 had popped up online-And the bends, breaks and folds were simply: “Character.” I bought them before I could blink.
....Today, they arrived-I noted the crushed box with multiple rips. My heart sank.
Opening the crushed box, I pulled out equally crushed and torn top irons.
Did I mention that I love a good challenge?
I’m using a: “Trash-Can Electrolysis Tank,” and I’m about to soak the irons for a few days. Once I see what I’m left with, I’ll happily photodocument my restoration of the: “World’s Worst Top Irons.”
...Stay tuned for more! This will take a *lot* of straightening, brazing and luck (As well as a few beers and a *lot* of swearing!) but if I can get these irons sorted out, there’s hope for all restorers on a budget!
- First Name: Bob
- Last Name: McDaniel
Re: Fed-Ex!!!! How *could* you!
Sorry to hear Fed Up did it again. I have no idea why anyone would still ship anything with them. I have had them drive around my house for 3 days only to send me a note in the mail that they can not find my address and my wife and I even stood in the yard waving our arms in the air as they drove by. We are the only house left on what is now old St. Rd. 25 so its not like we are hard to see. Then when I do get the package it looks like they tied to the rear bumper and the contents will be toast unless it was packed by superman. Sometimes they drop off packages here that are not even mine! I do have a post at the end of the driveway with the address on it but they can't read it I guess. Please don't send me anything with Fed Up, the worst shipper in the world.
Curses! If the packaging was seriously damaged by F-E ? I do hope they will at least compensate you for purchase price or some token amount if they were free?
I have had some remarkable success with electrolysis de-rusting. I have also had many dismal failures. Apparently, when the chemical is fresh, and all the electrical connections clean and solid, it works well. But it doesn't seem to last long. The process is by its very nature self-destructive. It does NOT clean inside tubes, cylinders, or other confined spaces very well. It prefers what would amount to line-of-sight. I did clean some confined spaces by insulating a probe line and poking the non-insulated end inside the rusty item. Required switching the battery connection from the fixed electrode inside the tank to the probe. And you have to be careful not to short out the tank by touching the probe to the object. It worked, but not great. The electrical action wants to move the water along with the rust particles (fascinating to watch in a tank that is working well!), and the confined space restricts the desired motion.
Thin-wall electrical conduit can be cut to length and split lengthwise and shaped to fit to create splices. Placed inside one area (usually the lower end) and brazed into place. It may be wise to drill a few (3/8 to 1/2 inch) holes in spots to spot-braze for additional stability. The tighter the splint fits, the better. Replace broken pieces and finish braze.
Later top sockets can usually be forced open to get inside somewhat to aid straightening, and brazing of splints. Then carefully (usually heat will be required) re-closed and usually spot-brazed/welded to hold closed and in shape.
It CAN be done! Especially with a bit of creativity and by someone that likes a challenge.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
To tell you the truth it sounds like you were actually expecting junk anyway. Good luck or the repairs.
I have had luck de-rusting parts using a phosphate product - Krud Kutter Rustex-Rust Converter. There are many similar products, this one is biodegradable. Small stuff I drop in a bucket, straight stuff in a PVC Tube, odd shapes I wrap in some paper shop towels lay in they down in an old heavy shower curtain and keep the towels wet and wrapped in the plastic to prevent evaporation. Only takes few hours and the wash/wire brush residue off. When done the items have a bluish tinge. The solution is reusable many times over - $25 a gallon.
....Charlie, as a fella originally promised the top irons in an online “con,” I’ve learned to expect the worst-But appreciate the best! Since it appears the original company that made replica ‘26-7 top irons decided to discontinue them, *none* of the major parts suppliers seem to have them in stock-Even at the four-figure price bracket!
...Regardless of whether or not my restoration process works or not, perhaps I can provide valuable insights on: “What and what *not* to do!”
TRD Bx2-I was actually just looking into similar products!
I posted these before. Started out with the rust photo, the second photo: brown plate is after the residue was washed off, the silver plate is after wire brushing.
I guess the package was insured or it should have been. How was it packaged? I’ve had packages damaged by UPS but so far none by Fedex. It both instances the boxes weren’t packaged well or incorrectly. UPS paid in full for the damage and then some. And I kept the items and repaired them.
Since my item losses with UPS I now always over box items I ship and hope they get there OK. And adding fragile labels don’t help.
- Last Name: Patrick
If you receive a package that is obviously damaged, when you sign that you received it, you should ask the driver to note that the package arrived damaged. You should take photos of the unopened, damaged package, with the label, prominent in the pictures, then document, with pictures, the opening of the package, then the unpacking of the contents. If the contents are not damaged, be happy and delete the pictures. If the contents are damaged, you have photos to document the opening of the package to submit to the shipper for an online claim at their website. If the damaged item was purchased on eBay and was paid for with Paypal, in most cases, Paypal will refund the full amount,including shipping, if you cannot resolve it with the seller after a certain amount of time and it is determined the seller was negligent. I have file many claims in this manner and have won all of them. Jim Patrick
- Last Name: Morsher
I’ll step in here as someone who ships a lot, fed ex is the only choice for me. We have shipped large stuff for years and tried them all. Believe me. Our stuff always arrives safely because we overpack. Snug, padded, double, sometimes triple boxed. On the occasion where something cannot be damaged, shrink wrapping is something fedex allows, and UPS doesn’t. That makes a big difference in shipping cost, as dimensional weight is what they charge. Sometimes it makes a difference between fed ex and truck freight. AGAIN, shrink wrap is only good for something that cannot be damaged. We still try to pad the edges with cardboard. Good marking on shipment is important, and also a tag inside. On unwieldy stuff, tying cheap rope to the package will be much appreciated by the carrier, and cut down on rough handling. Something that helps grab the package. I’ll agree with Bob, sometimes rural locations are a challenge , on pickups and on delivery.
I think the original post wasn’t about anything fedex did wrong. When you buy a sows ear, you can’t expect to receive a silk purse.
Forget about ever getting a claim paid by UPS. We’ve not had a claim with fedex, EVER, so not sure about them. My mantra is a great packing job is the best insurance.
- Last Name: Grzegorowicz
U P S UNITED PARCEL SMASHERS
