Heavy conn rods
Mel King
First Name: Melvin
Last Name: King
Heavy conn rods
Post by Mel King » Sun Mar 08, 2020 6:23 pm
Who would rebabbitt heavy rods and return them ? MEL.
Joe Bell
First Name: Joe
Last Name: Bell
Re: Heavy conn rods
Post by Joe Bell » Sun Mar 08, 2020 6:53 pm
Mel, why would you want to? they take twice the babbitt and hammer out quicker because of that. There is plenty of light rods out there to replace those, unless you are after heavier weight for rotating mass?
John Warren
Last Name: Warren
Re: Heavy conn rods
Post by John Warren » Sun Mar 08, 2020 8:32 pm
Joe, when you say that they take more babbitt, I am assuming that the base ID diameter is larger?
Re: Heavy conn rods
Post by DanTreace » Sun Mar 08, 2020 9:31 pm
Two types of heavy rods, C -type , pre-1915 have bore of 1 1/2" with 1/8" thick babbitt.
B-type, 1915-early 1920 heavy rods have same bore as the light rods (late 1920 and on), bore of those is 1 3/8" with 1/16" thick babbitt.
Joe Bell
First Name: Joe
Last Name: Bell
Re: Heavy conn rods
Post by Joe Bell » Sun Mar 08, 2020 9:48 pm
Dan, hit it on the nose!
Les Schubert
First Name: Les
Last Name: Schubert
Re: Heavy conn rods
Post by Les Schubert » Mon Mar 09, 2020 11:24 am
Well that explains something I have wondered about.
Back in the T era there were crankshafts made with 1-3/8” crank pins. The advertising implied that they could be used with T rods, and now I understand that this is true!!
Further I have one of these cranks!!
