Hello guys,
I will soon have to replace my connecting rods because i'm out of shims. Doing so, should i replace my cast iron pistons with aluminum ones?
I know the question was debated again and again, but i'm reluctant to aluminum considering all the problems of piston slap, seizing and so. Iron pistons have a bottom oil ring making piston slap almost impossible, but are heavier. On my car they are quite a lot oversize. If i go to aluminum, should i rebore my block?
Any opinions are welcome.
Pierre-Yves
Belgium
Pistons
Topic author - Posts: 6
- First Name: Pierre-Yves
- Last Name: Smits
- * REQUIRED* Type and Year of Model Ts owned: 1920 runabout
- First Name: Andre
- Last Name: Valkenaers
Re: Pistons
Bonjour Pierre Ives,
I like the cast iron pistons.
If it was mine and the cilinders are not bad, I should go just for a set new rings and keep the iron pistons.
Just my opinion.
Andre
Belgium
Just my opinion.
Andre
Belgium
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Pistons
I agree with Andre.
- Last Name: Smits
Re: Pistons
Ok thanks,
Merci André, i will stick to cast iron, but replacing the rings might be difficult, because it seems i have a set of aftermarket pistons as my piston rings are very different to stock ford rings.
- First Name: Philip
- Last Name: Thompson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
Re: Pistons
if the bore is standard used pistons are not hard to find. philip
- First Name: Andre
Re: Pistons
Pierre-Yves,
I send you a PM this afternoon with my email.
Andre
Belgium
Andre
Belgium
