accessories question
Anton Seelmann
Topic author - Posts: 27
- First Name: Anton
- Last Name: Seelmann
- * REQUIRED* Type and Year of Model Ts owned: Touring 19; Speedster 13/Rajo; Pickup 21; Tudor 25; Touring 25/Fronti; Touring 1909
Does anyone know the function of these accessories? I found it on a newly bought 1926 Ford Model-T. It was mounted between the carburetor and the intake manifold. There is a metal ball in each of the two small chambers. In the large chamber is a nozzle that comes from the wire jacket.
Re: accessories question
I understand it's purpose was to inject "moisture" into the cylinders to make carbon disappear - like magic !!!
Anton Seelmann
- First Name: Anton
Was the goal maybe a finer atomization?
Seems to be similar to this one, to provide finer atomization to the fuel. Some other types have a twisted wire and contacts for + _ to add battery wire to pre-heat the fuel for better starting. Think yours is this type:
Anton Seelmann
- First Name: Anton
Hi Dan,
thank you for original old advertisement. Now I can believe that it really helps or not.
greetings from Bavaria
