Kingston L4 Float setting
Tom Quigley
First Name: Thomas
Last Name: Quigley
* REQUIRED* Type and Year of Model Ts owned: 1923 Model T Touring, 1914 Model T Pickup; 1912 Model T Comm Roadster
Post by Tom Quigley » Wed May 13, 2020 11:27 am
I have located a couple of articles and consulted the MTFCA Carburetor book and cannot determine the proper setting for the float. One says one inch, another says 15/16'. Neither specifically mentions how or where to measure (e.g., from the machined surface to the float top; from the surface of the body to the seam of the float. ) I don't know the proper dimension or where to measure from-to.
I would welcome any assistance, Thanks TQ,
Re: Kingston L4 Float setting
Post by Mark Gregush » Wed May 13, 2020 11:55 am
Mine on page 11 shows 7/16 to top of float. All information I have see uses the machined area where the bowl sits.
Tom Quigley
First Name: Thomas
Last Name: Quigley
Post by Tom Quigley » Wed May 13, 2020 12:47 pm
Thank you Mark, I appreciate your reply. My Ford Carburetor book is (c)1988. P. 11 is absent any relevant information.
So, if I invert the body of the L4 and adjust the float measuring 180 degrees from the hinge; from the machined surface to the top of the installed float is 7/16 inches. Sorry to be so retentive, but I want to do this once.
Thanks again for the assist. TQ
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed May 13, 2020 1:09 pm
It is convenient to use a 7/16" drill bit, if you have one. Also, make sure the float is level with the machined surface at that gap. If the float is angled in any way, the setting will be off.
