Ford Special speedometer kits.
Sw1941
Last Name: Warthman
* REQUIRED* Type and Year of Model Ts owned: 1 1927 Coupe, 1 1914 Touring
Post by Sw1941 » Mon Apr 13, 2020 7:11 pm
Who is or was making the Ford Special speedometer kits? I'm in desperate need of one for a Johns-Mansville speedometer. Langs does not have them at this time.
Re: Ford Special speedometer kits.
Post by Mark Gregush » Mon Apr 13, 2020 8:36 pm
Welcome to the forum! I would suggest placing an ad in the classifieds looking for what parts you need. Unless you have some of the parts, the Special's would not be my first choice because of cost and not a lot out there. If you don't have a copy, you might want to get the Speedometer book from the suppliers to help ID the parts you will be needing.
maybe this will help;
https://www.ebay.com/itm/Ford-Special-1 ... SwOQNeY-te
By the way, as long as the drive arrangement is the same there are several speedo's that will work.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Mon Apr 13, 2020 8:53 pm
Russ Furstnow usually has one or two complete Ford Special setups on hand, all restored and ready to install.
1stnow@msn.com
