Piston clearance again
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Mar 27, 2019 10:28 pm
Its been a while since I rebuild a motor. Is the consensus on new aluminum piston clearance still .005"?
Re: Piston clearance again
Post by RajoRacer » Wed Mar 27, 2019 10:32 pm
That's about where I do mine .004 +++ to .006.
RGould1910
Last Name: Gould
Post by RGould1910 » Thu Mar 28, 2019 12:09 am
Thanks Steve.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Thu Mar 28, 2019 12:57 am
What kind of piston- forged or cast- it makes a difference.
RGould1910
Last Name: Gould
Post by RGould1910 » Thu Mar 28, 2019 10:50 am
I recall David Daigh, a respected rebuilder in N. CA, now retired, told me once he set the clearance at 2 thou. He used Egge pistons. The folks at Egge also told me many years ago to set the clearace at 2 thou.
On the rebuild I am doing now, the Egge pistons installed 40 years ago had 2 to 3 thou clearance. Do these require a closer fit than those sold by Langs and Snyders and formerly Vintage Ford? I see Chaffins currently sells Egge pistons. Is the difference that one is cast the other forged? Insights welcome!
