Genny cutout
Flyingpiper59
First Name: Edwin
Last Name: Douglas
* REQUIRED* Type and Year of Model Ts owned: 27 Tudor
Genny cutout
Post by Flyingpiper59 » Mon Oct 24, 2022 8:27 pm
Good evening Forum Chums, can anyone tell me where I might be able to get an original style can type cut out for my generator I didn’t see one on Langs… Many thanks in advance
Code: Select all
Moxie26
Last Name: Jablonski
Re: Genny cutout
Post by Moxie26 » Mon Oct 24, 2022 8:47 pm
Call Snyder's Antique Auto parts, ask for the cutout made by Nu- Rex, negative ground with a script on the cover, for the standard 6 volt negative ground battery....... 330-549-3313. Ohio.
Last Name: Hjortnaes
Re: Genny cutout
Post by DHort » Mon Oct 24, 2022 10:31 pm
Cheaper to buy direct from Nu-rex at www.nurex.com
Item T-10505-SS
Re: Genny cutout
Post by TRDxB2 » Tue Oct 25, 2022 2:01 am
Nothing wrong with t he Nu_Rex diode cutout other then their claim that you can use it to get 20amps out of your Model T generator. It is true, but it will kill you generator. Many discussions caution setting the 3rd brush to output more than 10amps and most recommend 5amps.
Moxie26
Re: Genny cutout
Post by Moxie26 » Tue Oct 25, 2022 8:28 am
Nu-Rex also sells more accurate amp meters than what we have been using in the past.
Moxie26
Re: Genny cutout
Post by Moxie26 » Tue Oct 25, 2022 9:10 am
My mistake I believe with the ammeters, I posted before I had my morning coffee
RVA23T
Last Name: C
Re: Genny cutout
Post by RVA23T » Tue Oct 25, 2022 4:14 pm
I just had my afternoon coffee and I think this is the Ammeter site you had in mind: www.westach.com/ammeters
Moxie26
Re: Genny cutout
Post by Moxie26 » Tue Oct 25, 2022 4:18 pm
Richard, you must have read my mind. That's the exact company I was going to call for a quality 20- 0 - 20 amp meter.
Flyingpiper59
First Name: Edwin
Last Name: Douglas
Re: Genny cutout
Post by Flyingpiper59 » Tue Oct 25, 2022 9:45 pm
Thanks all!
