FS headlight forks and front fender irons
T Cruiser
First Name: Ted
Last Name: VanBeek
* REQUIRED* Type and Year of Model Ts owned: 27 Touring, 13 Touring, 10 Touring
Post by T Cruiser » Wed Nov 23, 2022 9:13 pm
These are nice original forks ,and correct fender irons for13-14. $150.00 plus shipping. These will fit in a large usps flat rate box. Call Ted at 503-728-3476
Last Name: Wrenn
Re: FS headlight forks and front fender irons
Post by TWrenn » Thu Nov 24, 2022 9:27 am
More like '12-'13, IF indeed the extrusion between the lamp bracket hole and the frame mounting holes is fully round. The pic is hard to tell. In 1914 they changed the extrusion underneath the headlamp bracket hole which is now what I would call a slight "V" shape. And those style are a dime a dozen.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Thu Nov 24, 2022 10:53 am
Tim, is this the slight v-shape you are referring to on light bracket for a 14?
T Cruiser
First Name: Ted
Last Name: VanBeek
Post by T Cruiser » Thu Nov 24, 2022 3:20 pm
These are the later v style that was used in part of 13 and all of 14. My original un restored Feb. 13 has the early style,while a friend has Sept 13 has the later style. Many parts transitioned during 13. Ted
Last Name: Wrenn
Post by TWrenn » Fri Nov 25, 2022 10:02 am
No, that pic is of the headlamp fork... I meant the actual fender iron. The area between the fork hole and the 3 holes where it bolts to the frame. Up til '13 that short area was round, after that it was in the shape of a "V". Hope this helps.
Last Name: Wrenn
Post by TWrenn » Fri Nov 25, 2022 10:04 am
Kinda mis-typed there...not "up" til '13, meant to say "through" '13. Indeed, the very late '13s may have already had the "V" shaped iron, we all know how Henry did things. LOL
rickd
First Name: Rick
Last Name: Duquette
Post by rickd » Fri Nov 25, 2022 10:12 am
I understand now. Thanks.
