Transmission work
RGould1910
Last Name: Gould
Transmission work
Post by RGould1910 » Thu Feb 19, 2026 1:36 pm
Transitioning to a transmission. Did I really say that?
It's been a few years since I did transmission work. Is the consensus on triple gear bushing clearance still .005"?
Last time around I recall pin bluing at .003" but that could have been due to other causes.
Re: Transmission work
Post by speedytinc » Thu Feb 19, 2026 1:46 pm
That's my preference. .0045-.005"
But there are other aspects of the bushing lubrication to be optimized since this is a weak link.
After machining the flange clearance, cut a healthy chamfer, .090-.100".
With an 1/8" die grinder bit, cut a lead from the chamfer into the 2 oil groves.
I have transitioned to the Ford method of pin sizing the bushing from lathe boring. Not a fan of hand reaming.
Post by TXGOAT2 » Thu Feb 19, 2026 1:56 pm
Use of a suitable, light-bodied engine oil will help assure that the triple gear bushings get adequate lubrication, especially in new installations. I'd also want to limit the speed, load, and time spent in low or reverse until the parts had some run-time.
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Thu Feb 19, 2026 3:02 pm
Consider burnishing with stainless steel burnishing balls. It gives a hardened mirror like finish to the bushings and presses them into the bearings.
