Switching to Later Style Rod
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Oct 16, 2019 3:27 pm
I don't like the way the carb mixture rod is so far under the dash of my car and have seen the improved cars with the choke/mixture controls integrated.
Is that something I could retrofit onto my 24 Touring?
1924 Touring
Re: Switching to Later Style Rod
Post by RajoRacer » Wed Oct 16, 2019 4:11 pm
Sure can - need to acquire a couple different pieces but easy job. I modified a stock brass one for the '14 w/electric start that looks origianal from the cockpit.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Oct 16, 2019 9:34 pm
What, besides the improved car rod and knob, is needed?
1924 Touring
Post by Scott_Conger » Thu Oct 17, 2019 10:48 am
this: https://www.modeltford.com/item/6208B.aspx
and this: https://www.modeltford.com/item/6208B.aspx
and maybe this depending on what comes with your choke rod assy: https://www.modeltford.com/item/4131.aspx
assuming you are running an NH
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Thu Oct 17, 2019 11:38 am
Thanks everyone.
I put a want ad in the classifieds for a old set. If none turn up, I think I can put a new assembly together from Langs. The thought of a shiny new knob sticking out of my dashboard kind of gives me the willies ;) but I'll do what I have to do. ;)
1924 Touring
Post by Norman Kling » Thu Oct 17, 2019 11:44 am
Whatever you do, be sure to save the old parts, because some day when you or your estate want to sell the car, the purchaser might want to restore it to stock.
