mainbearing linebore unit
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sun Jul 17, 2022 9:45 am
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $1050 plus $150 crating and shipping in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
NEW PRICE ... this new INCREASED price reflects the current materials and shipping cost ... sadly , these cost increases and material supply issues may cause many small businesses to cease production or the supply of service ...while i do not benefit beyond the recovery of most of ,my materials cost again , i am saddened to announce this increase ,..
Gene_French
First Name: Gene
Last Name: French
Re: mainbearing linebore unit
Post by Gene_French » Sun Jul 17, 2022 10:57 am
Linebored main bearings
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Sep 24, 2022 11:18 am
to the top again ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Nov 26, 2022 10:19 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 08, 2023 9:53 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Feb 21, 2023 10:25 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Mar 24, 2023 10:52 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Apr 02, 2023 11:16 am
to the top again ...Thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat May 13, 2023 9:35 am
Patrick Goodman
First Name: Patrick
Last Name: Goodman
* REQUIRED* Type and Year of Model Ts owned: 1919 Runabout 1925 touring
Board Member Since: 2022
Post by Patrick Goodman » Thu May 18, 2023 12:17 am
What can be used to drive the shaft?
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu May 18, 2023 9:36 am
Patrick:
this is driven by your 1/2" drill motor ... others have rigged an elaborate feed system by using a milling machine or lathe ... my design works well with a simple drill motor and hand feed ... boring bit is ground with a left hand lead ... this causes a slight resistance to the feed motion allowing a controllable feed ... you may call for additional info ... i will send an email with the proceedure sheets in an attachment ...Gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jul 02, 2023 10:22 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Oct 01, 2023 11:23 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Dec 01, 2023 10:18 pm
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Jan 18, 2024 9:55 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Mar 28, 2024 10:02 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jun 15, 2024 10:09 am
to the top again , thanks MTFCA ( i am on my 667 th. linebore unit since 1979 , i skipped #666 )
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sat Jun 15, 2024 3:14 pm
Your products are outstanding. Just wish I could afford them.
William L Vanderburg
1922 Center Door Sedan
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jul 13, 2024 9:14 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Aug 04, 2024 9:08 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Aug 29, 2024 9:26 am
to the top again ... thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Mon Nov 04, 2024 2:59 pm
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jan 04, 2025 10:55 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 26, 2025 10:58 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Feb 13, 2025 9:15 am
have made another run of linebore units for this years sales ... will have several on display at the Duncan ,Ok. swapmeet in March ... you can save shipping on a unit and pickup at the meet ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Apr 18, 2025 8:38 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 30, 2025 10:00 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jul 05, 2025 8:32 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Nov 08, 2025 8:29 am
dunnds
First Name: David
Last Name: Dunn
* REQUIRED* Type and Year of Model Ts owned: 1922 T Tourer; 1922 TT Truck; 1915 T Tourer
Post by dunnds » Wed Nov 19, 2025 1:59 am
Hi Gene, My name is David Dunn and I would like to talk to you by email as I live in Australia. My email is dunnds@bigpond.com
