mainbearing linebore unit
Gene_French
Topic author - Posts: 1040
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $1050 plus $150 crating and priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
NEW PRICE ... this new INCREASED price reflects the current materials and shipping cost ... sadly , these cost increases and material supply issues may cause many small businesses to cease production or the supply of service ...while i do not benefit beyond the recovery of most of ,my materials cost again , i am saddened to announce this increase ,..
Gene_French
- First Name: Gene
- Last Name: French
Re: mainbearing linebore unit
Linebored main bearings
Gene_French
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ...Thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Patrick Goodman
- First Name: Patrick
- Last Name: Goodman
- * REQUIRED* Type and Year of Model Ts owned: 1919 Runabout 1925 touring
- Board Member Since: 2022
What can be used to drive the shaft?
Gene_French
- First Name: Gene
- Last Name: French
Patrick:
this is driven by your 1/2" drill motor ... others have rigged an elaborate feed system by using a milling machine or lathe ... my design works well with a simple drill motor and hand feed ... boring bit is ground with a left hand lead ... this causes a slight resistance to the feed motion allowing a controllable feed ... you may call for additional info ... i will send an email with the proceedure sheets in an attachment ...Gene French 970-581-2808
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again , thanks MTFCA ( i am on my 667 th. linebore unit since 1979 , i skipped #666 )
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
Your products are outstanding. Just wish I could afford them.
William L Vanderburg
1922 Center Door Sedan
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ... thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
have made another run of linebore units for this years sales ... will have several on display at the Duncan ,Ok. swapmeet in March ... you can save shipping on a unit and pickup at the meet ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
Gene_French
- First Name: Gene
- Last Name: French
