Camshaft Rear Bearing Reamer Bar
vanco
Last Name: Van Cott
Post by vanco » Tue Feb 03, 2026 9:16 pm
WTB: Or (Borrow One). Camshaft rear bearing reamer bar that is put through the camshaft journals to align bore the rear bearing. Just trying to rebuild my T engine the proper way. I don't have a lathe to make one, any help would be appreciated!
Thanks, John
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Re: Camshaft Rear Bearing Reamer Bar
Post by BRENT in 10-uh-C » Wed Feb 04, 2026 9:11 am
Thanks, John
Do you have a picture??
Last edited by BRENT in 10-uh-C on Wed Feb 04, 2026 9:18 am, edited 1 time in total.
cwhuntersr
First Name: CW
Last Name: Hunter
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup
Post by cwhuntersr » Wed Feb 04, 2026 9:36 am
Last Name: Hatch
Post by Dan Hatch » Wed Feb 04, 2026 10:10 am
Pictures worth a thousand words
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Wed Feb 04, 2026 10:31 am
This is mine. I have multiple standard and undersized reamers. I think these are jig bore reamers. Had it made so it can be powered by a drill motor, wrench or piece of bar stock. Cost about $250 to have it made locally. May be a little too far from you though.
Brad
vanco
Last Name: Van Cott
Post by vanco » Wed Feb 04, 2026 5:54 pm
Thanks for the photo's and information! To my knowledge there are not any model t ford clubs in Utah so I joined the MTFCA so that I have some information flow. Possibly I can find a machine shop in the area that would consider making one, most shops I have found do not have the time or interest in model t fords. It is all about available time and money. Thanks everyone, John
First Name: john
Last Name: karvaly
Post by speedytinc » Wed Feb 04, 2026 6:15 pm
Is this tool really necessary? Does every motor re-builder use one? Does the service manual refer to this procedure?
Do you have a reasonable suspension that your block's cam mounts are out of alignment?
vanco
Last Name: Van Cott
Post by vanco » Wed Feb 04, 2026 6:36 pm
I'm not sure, I guess that I should do some more research? I have seen Mike Bender use one on his engine rebuilds as well as others in the past. My engine requires that a new bearing be installed.
Post by RajoRacer » Wed Feb 04, 2026 7:36 pm
I've used mine on every engine out of my shop for the last 30 + years !
Last Name: Hatch
Post by Dan Hatch » Wed Feb 04, 2026 7:45 pm
Every engine
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Wed Feb 04, 2026 7:54 pm
Re - Utah Model T Club Chapters:
While I don't see any chapters listing for MTFCA or MTFCI being in Utah there was a Model T Ford Club International annual tour in 2013 out of Kanab Utah.
I did not attend or remember who put it on.
But I will guess that Model T Speedometer expert Russ Furstnow (Flagstaff, Az) is nearby and might know of Model T folks in the area.
viewtopic.php?f=2&t=51605&p=386741#p386741
Also see this posting
viewtopic.php?f=2&t=51412
And remember, if there is interest in the area start your own chapter!
And for my Camshaft Rear Bearing Reamer I used a nice shaft, made adapter sleeves, and an adapter to take "stock" reamers to get the job done.
I made my own.
Mike
First Name: john
Last Name: karvaly
Post by speedytinc » Wed Feb 04, 2026 8:01 pm
Every engine
Rajo & Dan;
Do you perceive that The rear bushing was off some , therefore requiring this operation??
Does the lifter relief notch pull your reamer a bit?
If you were installing NOS iron bushings that fit the cam without reaming, would you still do this?
Last Name: Hatch
Post by Dan Hatch » Wed Feb 04, 2026 9:40 pm
Every engine through my shop
Post by RajoRacer » Wed Feb 04, 2026 9:43 pm
No - just seems to be a good practice being how flimsy a T camshaft is.
Not that I perceived.
Anytime a bushing is installed as a "press fit", no matter what the material the bushing is made of, reaming is prudent.
Post by RajoRacer » Wed Feb 04, 2026 9:45 pm
Perhaps the moderator would see fit to pull some of this content over to the discussion area - sorry for jumping in with comments !
vanco
Last Name: Van Cott
Post by vanco » Thu Feb 05, 2026 12:32 am
WTB: I am interested in buying a camshaft rear bearing reamer bar if anyone has one for sale. Thanks everyone for your input, John
Last Name: Hatch
Post by Dan Hatch » Thu Feb 05, 2026 4:06 am
I looked into reproducing them, but the cost was outrageous. So I decided not to.
Last Name: Hatch
Post by Dan Hatch » Thu Feb 05, 2026 10:13 am
Here is the numbers on mine. Looks like it maybe a Z tool?
vanco
Last Name: Van Cott
Post by vanco » Thu Feb 05, 2026 12:14 pm
Thanks Dan for the information and photo's, I will keep looking as I believe that is the way to go with regard to aligning the camshaft properly. If anyone out there has one that they want to part with contact me. Thanks Again everyone!!
vanco
Last Name: Van Cott
Post by vanco » Fri Feb 06, 2026 12:36 am
To The Top
