License Plate Bracket on 27 Coupe
Topic author - Posts: 23
- First Name: Steven
- Last Name: Smart
- * REQUIRED* Type and Year of Model Ts owned: 27 Coupe
Hello:
I am restoring a 27 coupe (American Car). The car was relatively complete and original.
The front license plate was mounted by a couple clamps that wrapped the headlight bar.
I did not think this was original.
I was wondering if anyone had supporting documentation of this or were they all mounted on a bracket that came off the front engine mount?
Thanks in advance.
Steve
Thanks in advance.
Steve
Re: License Plate Bracket on 27 Coupe
When the bumpers became an option, the front bumper blocked the view of the front plate when mounted under the radiator. They offered the clamps to mount on the headlight bar so the plate could be located higher in front of the radiator.
This thread talks about that.
http://www.mtfca.com/discus/messages/41 ... 1390852415
- Last Name: Codman
My '27 has the plate bracket mounted below the crank lever. I don't know if it is original or not, but it looks to be so.
- Last Name: Smart
Thanks all for your input.
Greatly appreciated.
Steve
Steve
- First Name: Les
- Last Name: Schubert
If it was a Canadian car, I had some of those made a couple of years ago that mount the plate just under the left headlight. I might have one available
Not sure if the two hole one is correctly constructed
These are examples of original Ford front license plate holders sans the early 2 pc. ones. The 3 side by side are stamped '26 - '27 - why the one has an additional hole is puzzling. The single one at top is pre '26.
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
This is my Canadian bracket, if any one would like more detail, I'm here.
Work honestly
Stay true to your word
Get the job done right
- Last Name: Smart
Thanks all for the replies.
Steve
Steve
