Coil Test Tube Ball Bearing Thingy
Topic author - Posts: 732
- First Name: Danny
- Last Name: Deaton
Somewhere I read the article on how to build this and cannot find it now. I saw one in action at the homecoming and didnt take time to ask about it. For some reason I want to make or purchase one. Anyone have any leads? I dont know the correct name of the thing to do a search.
Thanks in advance.
PS, I am a control electrician and thats why the interest in the odd stuff.
Thanks in advance.
- First Name: Howard
- Last Name: Tomlinson
Re: Coil Test Tube Ball Bearing Thingy
Isn't that a electric fence charger?
- First Name: Ed
- Last Name: Martin
- First Name: George John
- Last Name: Drobnock
Search LeJay stuff or see: http://www.mtfca.com/discus/messages/50 ... 1440780666
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Here’s the drawing from the Lejay Catalog.
Lejay also made a kit.
Here is a photo of the one I have in my coil archive.
- First Name: Don
- Last Name: Keil
got one that was missing tube found that a rain gauge tube works fine. use glass marble not ball bearing.
- First Name: BOB
- Last Name: CASCISA
A Test Tube works great for a glass replacemnet.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- Last Name: Hatch
If anyone does not have a LeJay manual, you need to get one. Lots of info!
That is where I learned to rewind generator armatures. Has info for all types of early auto electrical. You will be surprised what you can make out of a T generator or starter. Dan
- First Name: Danny
- Last Name: Deaton
Got some things to look for at Hershey.
- First Name: Don
- Last Name: Keil
the fuse Is a good addition. when I got mine the points were welded together and the springy part witch the ball hits was burned in two. had to make a new one. a rain gauge tube is about the same length as the coil box looks neat except for the numbers.BE_ZERO_BE wrote: ↑Tue Jul 20, 2021 1:34 pm
- First Name: BOB
The "fuse" is actually the glass from a fuse with two electrodes and a spark gap inside.
In addition to the three neon light bulbs, it is an visual display of the spark when the coil fires.
Be_Zero_Be
Be_Zero_Be
