Good source for Wooden Steering Wheel Rims
OilyBill
Topic author - Posts: 683
- First Name: William
- Last Name: May
Anyone know a good source for wooden steering wheel rims, such as on early Ford cars, or Model T's? The kind that nest into the 4 spider spoke ends, and are held in place with a screw on each arm of the center spider? I need to find a source for a wooden rim for two 1912 Overland automobiles. The original deteriorated rims were wood, and are just 1/2" larger in diameter than a Model T steering wheel rim, so I cannot use a Model T wood steering wheel, but they are virtually identical in style and shape of the wood rim area. Anyone know someone who made a Model T wood rim for them, and could make a slightly different size?
Thanks to all!
Thanks to all!
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Re: Good source for Wooden Steering Wheel Rims
Do you have a diameter?
I have a few wooden wheels that are not T’s
Scott
Scott
rickd
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Snyders carries a good selection of finished steering wheels. Maybe they can help you?
gldavis
- Last Name: Davis-Williams
I bought a steering wheel from this vendor several years ago, and I've been very happy with it.
https://woodbykevinallen.com/model-t-st ... heels.html
George Davis-Williams
Lake City, MI
1926 Tudor
Lake City, MI
1926 Tudor
TMiller6
- First Name: Thomas
- Last Name: Miller
- Board Member Since: 2006
Noah Stutzman can also make wooden steering wheel rims. Years ago he told me if I bring him the metal spider, he can go from there.
It’s also fairly easy to make your own by cutting 16 pieces of wood and gluing them with overlapping joints. I made it round by using a router bit and a turntable on my drill press.
Tom Miller
South Park Zephyr
I have these that are not Model T wheels if they might be what you are looking for
Scott
Scott
South Park Zephyr
One more that wouldn’t fit with the previous post
Scott
Scott
kmatt2
- First Name: Kevin
- Last Name: Matthiesen
I have had good luck with Kevin Allen , at Wood by Kevin Allen , he does excellent work and can make a custom wood wheel to fit your stock steering wheel spider, provided you have a spider for your car that you can send him. I see that Kevin’s contact information has already been posted in this thread, so check above for that information .
Jack Putnam, in Ohio
- First Name: Jack
- Last Name: Putnam
Noah Stutzman. Makes steering wheel wooden rims. Made from a single piece of steam bent wood with a finger joint. He can make them round, oval with or without finger grips. Excellent Amish craftsmanship. Stutzman wheel shop 330 897 1391, Baltic, Ohio
