Duncan,Ok. swapmeet wanted to buy
Gene_French
Topic author - Posts: 1109
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
i am starting this post in possibly the wrong section BUT ... the Duncan,Ok. swapmeet is coming up in March and i am attending to sell as well as purchase some parts for my projects ... i am WANTING TO BUY ...a windshield frame for a 1931 Murry body model A 4dr., Masonic items from the 1900-1930 era , and 4 cyl. Dodge Brothers items ,particularly 5 lug 20" and 24" disc wheels ...i encourage you to attend this meet as well as post wanted to buy or for sale at Duncan swapmeet ... this meet will likely continue to grow and be of interest to hobbyist as well as commercial vendors ...hope to see you there ...Gene French
BillM
- First Name: BILL
- Last Name: MAULDIN
- * REQUIRED* Type and Year of Model Ts owned: 1923 Coupe
Re: Duncan,Ok. swapmeet wanted to buy
I'm going this year. I'm looking for 23 coupe (suicide doors). interior parts and passenger side door latch.
Gene_French
- First Name: Gene
- Last Name: French
i will be bringing sets of rebabbitted model T connecting rods and some single rods and re-babbitted ballcaps, have several mainbearing cap sets also,these may allow for "adjusting" the rear thrust problem in many well used engines , several aftermarket distributors including Atwater-Kent , Delco and Bosch and what i believe to be a 4 cyl. Chev. distributor and a Northeast ignition for 4 cyl. Dodge Brothers , some generators and starters and a alternator for Model T ... i will also have my babbitt bearing molds and linebore units onsite ...you can save a bunch on postage and crating with the linebore units ...i will also be looking for sets of T rods to re-babbitt ...see you all there ...Gene French
Gene_French
- First Name: Gene
- Last Name: French
in addition to the windshield i am also looking for front fenders for the 1931 model A 4dr. ... i have fenders that are rusted thru at the headlight bar bolt holes ... this is strange since this is the only rust out on the vehicle ... i had seen patch panels in the past ,BUT , not recently ...also a good title for the 1931 4 dr. ... Gene French
Mike Silbert
- First Name: Mike
- Last Name: Silbert
For fender patch panels try Snyders, I am not associated with them
https://www.snydersantiqueauto.com/prod ... 6848&cat=0
or
https://www.snydersantiqueauto.com/prod ... 6846&cat=0
Someday I would like to attend Duncan Pre-War, but not this year.
Mike
or
Mike
Gene_French
- First Name: Gene
- Last Name: French
have been going thru my " collection" of stuff ( my sweetie refers to this stuff as JUNK) ... in addition to my usual babbitt bearing tools i will be bringing a batch of various items collected from past projects and bulk parts purchases ... will probably have some radiators , headlights , 26/27 fuel tank ,a bunch of misc. carburators and distributors ... looking forward to the meet ...hope to see you all there ...Gene French
Gene_French
- First Name: Gene
- Last Name: French
spoke with Kevin Hammock this afternoon regarding times that vendors could enter the buildings for setup ... Wednesday evening after 5:00 for vendors with LARGE trailers ...this is done to reduce the clutter of smaller vehicles and foot traffic and hopes to reduce the difficulty of placing long trailers ... general vendor access is at 7:00 Thursday morning ...this is done for the LARGER trailers in hopes of reducing the excess clutter and foot traffic interference ...hope to see you all there ...Gene French
tmodeldriver
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
I might be in Oklahoma in March. What are the dates? Thanks.
Gene_French
- First Name: Gene
- Last Name: French
Robert:
March 26 thru 28 are the dates ... this promises to be an even better meet than last years event ... very good facility and many good vendors ...as with most swapmeets the majority of items are the common items , there were some good sheetmetal and brass items and unusual interesting specality items also ...i had good sales and was able to purchase some rebuildable cores and a Rajo cylinder head and Dodge Brothers steering wheel ,a North-East horn and some Masonic historical items ...i expect to have this meet on my calendar for many years ...Gene French ( north building with my babbitt bearing tools )
Gene_French
- First Name: Gene
- Last Name: French
Since this is a Duncan swapmeet "wanted to buy " listing ... i am also looking for a 1 barrel downdraft manifold for a Model A ... i know that the large vendors have the weber and stromberg manifolds BUT, i have had great results with the old Holley side bowl carbs. and prefer the simple carb unit ...also looking for T rod sets to re-babbitt ...Gene French
Texasroadkill
- First Name: Clint
- Last Name: Bitterly
- * REQUIRED* Type and Year of Model Ts owned: 1923 pickup
- Board Member Since: 2012
I'm looking for a set of body to bed filler panels for a 26-27 roadster pickup. There almost teardrop panels that fill the space between the bed and body.
Thanks.
Thanks.
BillM
- First Name: BILL
I'm looking for a set of 23 coupe inside door pulls.
Gene_French
- First Name: Gene
- Last Name: French
regarding the windshield frame i am looking for ... this is for a 1931 Murry body 4dr. ... the windshield seems to be about 1 1/2" shorter in height than a standard model A windshield ... i may be able to cut a frame down and re-drill the screw holes at the top ? anyway , it seems that the Murry slant windshield frame is different that the common model a frame ... Gene French
VinTin23
- First Name: Marty
- Last Name: Ray
- * REQUIRED* Type and Year of Model Ts owned: 1916 Runabout, 1922 Roadster
Looking for a decent set of wood fellow wheels, I’ll consider everything from Serviceable to rebuilt.
Art Ebeling
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
Gene, I think that 31 is called a slant windshield frame. There is no outside visor on a slant windshield Model A. The Victoria, A400, and Cabriolet are also slant windshields. ArtGene_French wrote: ↑Fri Feb 20, 2026 6:54 pmregarding the windshield frame i am looking for ... this is for a 1931 Murry body 4dr. ... the windshield seems to be about 1 1/2" shorter in height than a standard model A windshield ... i may be able to cut a frame down and re-drill the screw holes at the top ? anyway , it seems that the Murry slant windshield frame is different that the common model a frame ... Gene French
Gene_French
- First Name: Gene
- Last Name: French
Art:
yes this is the Slant windshield 4dr. Model A ... a very good looking auto. ... the lack of visor and slanted windshield gives a whole different , more modern styling to the Model A ... additional trim pieces make this a "delux" model ... anyway , the windshiels is missing on this car ... i purchased from an estate , partially dis-assembled ...Gene French
Gene_French
- First Name: Gene
- Last Name: French
also looking for a 4r44e automatic transmission for 1995 4x4 Ford Ranger ... i know this is NOT pre 1949, but another item i am in search of ... this is for the 3.0 v6 engine ... i am told that this is same as 2.3 bellhousing pattern ... possibly just the bellhousing section can be changed and another auto. trans will work ? not sure if a pre electronic control trans. will work ? just 4 more weeks till the swapmeet , i am getting items ready , see you all there ...Gene French
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Gene,
Here are several to choose from, some rebuilt, you would need to look at distance from you to judge the value.
Scott
Scott
dobro1956
- First Name: Donnie
- Last Name: Brown
VinTin23, I will be bringing 5 wood felloe wheels. They are pretty good wheels ... Im in the North building. I think its building - A. Look for a 2021 Tacoma with a roof top tent. We camp on the spaces ...
dobro1956
- Last Name: Brown
Want to buy 1920s 30s pre-WW2 camping related items. Anything related to Motor Camping
Want 1920s 30s pre-WW2 era camping gear or any related items. Im in the North building. Look for the 2021 Tacoma with a rooftop tent. We camp on the spaces. We are there the whole swap meet.
Gene_French
- First Name: Gene
- Last Name: French
probably will not bring my trailer ... i have sold the 1927 wire wheel chassis ... will have the pickup packed to the gills and probably have to strap some items on the down tailgate ... will look like the Joads returning to Oklahoma ! meet will be here soon , looking forward to seeing many friends there ...be safe ..Gene French
Gene_French
- First Name: Gene
- Last Name: French
adding another item to my "wanted to buy" list ... will be looking for Gordon-Smith model A air compressor parts or info ... Gene French
Gene_French
- First Name: Gene
- Last Name: French
also will purchase model T connecting rods for re-babbitt ...Gene French
Gene_French
- First Name: Gene
- Last Name: French
will be starting to pack the pickup on Monday ... looking forward to this meet and hope all have a safe drive to and back home ...Gene French
