reducing 12v to 6v
Don ellis
Topic author - Posts: 383
- First Name: Don
- Last Name: Ellis
reducing 12v to 6v
I have a model a aooga horn I want to use. What's the best way to knock it 12 down to 6? besides putting a 6v battery in.
thanks
thanks
- First Name: Henry
- Last Name: Lee
Re: reducing 12v to 6v
A Dodge style ballast resister from the 1960’s works good.
Hope this Helps,
Hank
Hope this Helps,
Hank
Cambin
- First Name: Cameron
- Last Name: Smythe
- * REQUIRED* Type and Year of Model Ts owned: 1925 Duncan and Fraser 1/2 ton pickup and a 1922 Sydney built steenbhoms tourer
Hi Don I have done this with a piece of 0.8 mm stainless welding wire and cut about a foot and a half off and wound it around a half inch drill shank ant tried it then kept cutting it back until I got the right resistance
- First Name: Henry
- Last Name: Lee
Works well Cambin!
Hank
Hank
Cambin
- Last Name: Smythe
Yes hank works well
John.Zibell
- Last Name: Zibell
or just make a simple voltage divider. Two resisters of the same value, and tap from between them. Just be sure they can carry the current.
1926 Tudor
Don ellis
- First Name: Don
- Last Name: Ellis
Thanks guys, I’ll be trying some of these.
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
art32mor
- First Name: Art
- Last Name: Morra
- * REQUIRED* Type and Year of Model Ts owned: 24T Touring
Double resisyer will do it
A parts guys sell a unit ready to go
VW guy have one as well
Matt in California
- First Name: Matt
- Last Name: G
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
I have used wire like Hank above. I have also used a resistor (see picture). Depending on the current draw resistance values may need to be changed. A voltage divider with equal value resistors would be problematic for something drawing a lot of current. If the Horn drives around 1 Amp at 6 volts, a one ohm series resistor will drop 6 volts. I had a .6 ohm resistor handy it dropped about 4 V leaving 8 V on the horn.
Matt
Matt
